Home > Maintenance & Mods (L322) > Brake calipers improvement
Page 1 of 3 123>
nino_nino
A couple weeks ago I was changing brake fluid an notice that bleed valves are heavily rusted, so I ordered some stainless steel ones from this place in UK:
https://www.pro-bolt.com/stainless/stainle...er_dia=575
Much happier now. Very Happy
Nino,
Post #485519 9th Aug 2018 11:04am
That's a very good idea. It's amazing how many brake callipers have to be replaced due to corroded bleed nipples shearing off when trying to bleed the brakes. Thumbs Up
Post #485523 9th Aug 2018 11:42am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Nice Thumbs Up
A simple bit of preventive maintenance.
Probolt will probably wonder why there is a rush on stainless bleed nipples now Mr. Green Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #485540 9th Aug 2018 1:59pm
nice looking nipples Wink ... - .- -.
Post #485548 9th Aug 2018 2:27pm
Can you confirm the type you ordered please? M7?
Post #485594 9th Aug 2018 11:50pm
nino_nino
CTC - M10 (1 mm),
Nino,
Post #485601 10th Aug 2018 8:32am
Your link shows M7 shallow seat... Didn't want members ordering the wrong nipples sir Thumbs Up
Post #485613 10th Aug 2018 9:33am
nino_nino
Corrected, Thanks CTC Thumbs Up
Post #485616 10th Aug 2018 9:45am
Post #485617 10th Aug 2018 9:48am
Baltic Blue
Nino,
Do the front and rear calipers use the same type and size of nipple ?
Post #485627 10th Aug 2018 12:26pm
nino_nino
Mike, small visual difference (Brembo-TRW) but same size thread and length. PRO BOLT fit fine. in the picture left one is TRW
Nino,
Post #485644 10th Aug 2018 4:51pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Nino,
I’ll be doing this to my Brembo front/TRW rears shortly after seeing this post and noticing how my bleed screws are close to seizing when I did a fluid flush the other day.
I assume that you just clamp the soft hose and keep a rag handy to minimise any fluid leaking and prevent air getting up into the system when fully removing the bleed screw? Did you use any lubricant or copper grease on the bleed screw threads?
TYIA! Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!)
Post #640558 22nd Aug 2022 11:15pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Don't use grease on bleed screw threads unless you're very confident it's brake fluid compatible (most greases won't be).
At worst some of the grease could get back into the caliper while bleeding and contaminate the brake seals cause them to swell & fail.
You might be lucky & it never happens, but I wouldn't risk it - especially if you're fitting stainless parts. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #640561 22nd Aug 2022 11:51pm
Ajmngn
Seems like red rubber grease is the stuff for the job. Not sure of its longevity but I’ve bought a bunch of rubber dust covers and by mounting the retaining loop on the thread-side of the screw should provide a great seal to keep the road grime out and grease in! 🤞
 Andy
Post #640943 26th Aug 2022 10:33am
beemer5711
Wales
Have never thought about replacing for stainless before, great idea!
Post #641280 29th Aug 2022 8:36am
Page 1 of 3 123>
