![]() | Home > Wheels & Tyres > Smallest Wheel Sizes for L405 / Rear E-Diff Option |
LT Member Since: 13 Mar 2017 Location: South West Posts: 417 ![]() ![]() ![]() |
I haven’t found a 19” rim that will fit over the SDV8 brakes.
FFRR Mike Member Since: 30 Aug 2022 Location: Edinburgh Posts: 3 ![]() ![]() ![]() |
Thank you for your response on my query LT. 20” sounds like the way forward. |
You’re welcome |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 256 ![]() ![]() ![]() |
I have 255/55R20 Falkan AT-Trail all-weather tires I use on OEM wheels for off-road/winter use. They fit nicely over the brakes and provide lots of tire choices.
Correct, same in Canada. I should have said they are OEM RRS 20" wheels |
You can often pick them up very cheaply over here. I just preferred the style that I have. |
alboz01 Member Since: 13 Jan 2025 Location: SANDBACH Posts: 4 ![]() ![]() ![]() |
Are you still rocking the GG AT3's on your winter set? I have just bought the same set of alloys on eBay, now need some tyres.
If I was a purchasing a new set of tyres, I’d be leaning towards trying the Falken Wildpeak A/T AT3WA.
Thanks for your thoughts so far.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1553 ![]() ![]() |
In addition to the normal format 22" rims, I have a set of 255/60/20 pirellis all seasons on a set of defender L633 alloys. Those are same height, but slightly narrower than you're suggesting. The defender alloys also sit slightly further out than standard fullfat 20" alloys I believe.
