Home > Wheels & Tyres > Smallest Wheel Sizes for L405 / Rear E-Diff Option
Page 3 of 3 <123
FFRR Mike
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
Smallest wheel size for L405 V8
I know this has been discussed, a lot! But I couldn’t find any definitive resolution to the query.
My SDV8 is on 21 inch rims with the usual 275/45 Contis, which I have found a little scary at times on the wet motorway, particularly in comparison with the Falken Wildpeak AT3s (All season / 3 peaks) which I found the best on my Disco 4 and just cut through unavoidable standing water.
I’d like to go to a smaller wheel, so more sidewall, preferably with 255/60 or 255/55 Wildpeaks. Ideally this would be a 19” wheel, but the documentation says that my V8 cannot use smaller than 20” (as stated in previous posts). I’d prefer to use a 19” with a LR approved tyre size, rather than a 20” as the sidewall advantage without going beyond +3% would be minimal and this is stated as unsafe. Speed rating shouldn’t be an issue.
Views please!
Thanks. 2017 SDV8
Previously
2009 Defender 90 2.4 Tdci
2013 Discovery 4 SDV6
2009 Defender 110 2.4 Tdci
2003 Discovery 2 TD5
1987 RRC 3.5V8
(Defenders / Freelanders +++ professionally)
Post #641412 30th Aug 2022 10:33am
LT
I haven’t found a 19” rim that will fit over the SDV8 brakes.
I’m happy with the 20” rims though. I have a set with GG AT3’s for the winter when I’m negotiating muddy fields and tracks.
The 255-55-20 has the same sidewall height (5.5”) as the 255-55-19.
I’m pretty sure that the Falkens are available in 255-55-20. Thumbs Up
Post #641416 30th Aug 2022 11:26am
FFRR Mike
Thank you for your response on my query LT. 20” sounds like the way forward. Thumbs Up 2017 SDV8
Previously
1987 RRC 3.5V8
Post #641634 1st Sep 2022 11:02am
LT
You’re welcome Thumbs Up
It works well for me. I run two sets, the GG AT3 and Pirelli All Seasons.
The choice of AT tyres is limited in 255-55-20, but it’s slowly getting better. I’m wary of the sidewall strength of the GG’s.
Post #641657 1st Sep 2022 2:23pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I have 255/55R20 Falkan AT-Trail all-weather tires I use on OEM wheels for off-road/winter use. They fit nicely over the brakes and provide lots of tire choices.
 Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #641665 1st Sep 2022 3:26pm
LT
In the U.K. those are RRS rims. Thumbs Up
Post #641672 1st Sep 2022 4:19pm
Bora20
Correct, same in Canada. I should have said they are OEM RRS 20" wheels Laughing
Either way, these are your best bet. I found the wheels with working TPMS for $400 CAD on FB Marketplace. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #641674 1st Sep 2022 4:37pm
LT
You can often pick them up very cheaply over here. I just preferred the style that I have. Thumbs Up
Post #641675 1st Sep 2022 5:04pm
Page 3 of 3 <123
