![]() | Home > My Range Rover > Back with another Supercharged |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Well done David, a massive task and all finished to a high standard.
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
to be fair David that is not too bad for a fully sorted car that you intend to enjoy.
| bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 616
Great news, well deserved after all that work.
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640
It must be said following these updates that I have the upmost respect and admiration for you and your work. |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346
The RR is back |
| MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 621
Well done |
That’s the RR now done 250 miles since it passed it’s MOT and other then the fuel gauge moving at an alarming rate it’s been faultless |
David, i had this on my 2012 TDV8 and it turned out to be the center prop bearing was shot all the rubber around the bearing had perished or was perishing. now with all the work you have done i cannot remember if you have inspected this part or not. Bearings are cheap enough to purchase and with your workshop a straight forward job too. I also changed out the UJ while i was at it. 2012 Vogue 4.4 TDV8 - Current
Thanks Jayk.
| Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 408
Great to hear David - I'm getting 18.2 (Don't forget the .2) according to computer. That was on an hour run up the A1 to Peterborough for the Land Rover show at a steady 70mph. I can live with that - I would imagine the roads are more twisting and hilly up there so your mpg takes a hammering |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
Smiles per gallon mate that's all I can say |
Absolutely Bean!
Have only done around 300 miles in the RR at the moment.
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
On mine it was the front lower suspension bushes. |
