Home > Maintenance & Mods (L322) > Tow Bar?
Wiggins
2011 Range Rover Autobiography 4.4 V8 Santorini Black
Tow Bar?
I am looking for a detachable towbar as just bought a jet ski and seen one on eBay for £85 which is defo the cheapest on there and it's genuine, with the detachable one is that all you need? or is there more? Im just not sure, thanks
Post #64243 17th May 2011 7:25am
Martin
Site Admin
Have you got the tow bar socket (armature) fitted already?
Post #64253 17th May 2011 10:08am
Wiggins
no I don't think so, I removed my tow bar cover looked up and can only see the rear crash bar
Post #64254 17th May 2011 10:11am
tow bar cover?..
under the back you might have a 2'' square hole where the towbar slides into..if you have and you have electrics to the left ,you only need to buy the bit that goes in there....if you haven't then its a complete install for which there is loads of info on the forum re that..
Post #64255 17th May 2011 10:37am
Wiggins
as in the small plastic insert in the rear bumper that can be removed for your tow bar to go, I don't think I do have this square, don't really want the full install as I don't like the look of it, and just wanted one to remove and then fit when trailering
Post #64270 17th May 2011 12:38pm
there isnt a plastic cover on the bumper...
Post #64279 17th May 2011 1:24pm
dan_uk_1984
Do you have the square recepticle the tow ball slots into?
Post #64280 17th May 2011 1:34pm
Wiggins
I have the Overfinch rear bumper where there's a slot for the towbar, I'm not sure about this square will look when I finish work, what if there isn't a square? a full towbar needed?
Post #64282 17th May 2011 1:52pm
this is what you should see looking underneath at the back...
the square hole is where the tow bar goes in..
Post #64285 17th May 2011 2:06pm
Wiggins
Ahhh no I dont have this, take it I would need that first before anything?
Post #64287 17th May 2011 2:24pm
if you havnt got this 'bar' and square hole and electrics then you need a new full install...
Post #64288 17th May 2011 2:27pm
Wiggins
Ok thanks alot for your help folks Smile
Post #64290 17th May 2011 2:46pm
Post #64292 17th May 2011 2:58pm
stu
seems as good a place to post this as anywhere!!!
i changed the twin electrics on my car at the weekend to a single 13 pin euro socket to match up with my new caravan.
had the boot and doors open, ignition switched on to check all wires do what they supposed to with multi meter and some banging tunes ringing out.. Laughing
finished job and went back inside.
came out this morning to go to work for first time this week and got the click of death.... Shocked flat battery syndrome.... Sad
moral of the story, when using the battery power for a long period, make sure the car starts before you go in doors.
fortunately i have a jumper pack always in the car..... still feel a proper plonker though!!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #64332 17th May 2011 6:30pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Wiggins, you might not be able to fit a towbar with your back bumper.
I am sure there were 2 versions available - with or without towbar.
Post #64439 17th May 2011 11:31pm
