![]() | Home > Maintenance & Mods (L322) > Tow Bar? |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Have you got the tow bar socket (armature) fitted already? |
Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94 ![]() ![]() |
no I don't think so, I removed my tow bar cover looked up and can only see the rear crash bar |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35665 ![]() ![]() |
tow bar cover?..
as in the small plastic insert in the rear bumper that can be removed for your tow bar to go, I don't think I do have this square, don't really want the full install as I don't like the look of it, and just wanted one to remove and then fit when trailering |
there isnt a plastic cover on the bumper... |
Do you have the square recepticle the tow ball slots into? |
I have the Overfinch rear bumper where there's a slot for the towbar, I'm not sure about this square will look when I finish work, what if there isn't a square? a full towbar needed? |
this is what you should see looking underneath at the back...
Ahhh no I dont have this, take it I would need that first before anything? |
if you havnt got this 'bar' and square hole and electrics then you need a new full install... |
Ok thanks alot for your help folks |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
seems as good a place to post this as anywhere!!!
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2052 ![]() ![]() |
Wiggins, you might not be able to fit a towbar with your back bumper.
