Home > Technical (L322) > EGR cooler leak td6 2004
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
Morning Gents
I have been losing coolant and narrowed it down yesterday to the EGR cooler.
I have seen several threads about thermostat leaking and even complete removal.
Does it mainly seem to be the thermostat that causes leaks, it's not a massive leak more of a persistent drip and im topping up once a month perhaps.
Just want to be aware of any other usual suspects before i tear it down.
Thanks
Post #642754 12th Sep 2022 11:35am
Given the robust construction of the egr heat exchanger l would be surprised if that was the source of your leak ( to be proven wrong), the egr thermostat is however a different matter. There’s two possible sources of leaks from the thermostat body, namely the bleed screw and more likely the rubber o ring that connects it to the heat exchanger.
Changing the o ring isn’t difficult, just a case of removing the thermostat and a bit of a clean up and fitting the new ring which is available from duckworths.
Somewhere there is a write up by me as to how to easily remove the thermostat. Thumbs Up
Here you go,
Fifth post down,
https://www.fullfatrr.com/forum/topic8731....p;start=45
Post #642800 12th Sep 2022 8:14pm
Snowy90 L322
NIce Day thanks, that's encouraging, given the price of the thermostat might as well change it out, i havent got the fluctuating temperature thing yet but it seems to take longer to warm up!
Post #642843 13th Sep 2022 9:52am
If you are going to go for changing the engine thermostat, l definitely would, you will need to remove the engine viscous fan in which case removing the egr cooler complete with egr thermostat is straightforward.
I changed my engine thermostat last year, vast improvement in engine warming and final running temperature.
My mpg also went up surprisingly.
Post #642874 13th Sep 2022 4:57pm
Snowy90 L322
To be honest if it's just the thermostat that's leaking I'll probably leave the cooler/egr in place, rather keep it stock as far as possible.
Looking forward to getting that fan off not! it was off a few years back for an alternator so hopefully wont be too bad.
Post #642920 14th Sep 2022 9:21am
