Home > Technical (L322) > All doors unlocking
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
All doors unlocking
Is it possible to get all the doors to open when you open the driver's door? Tried searching online and through the cars menus butt can't find anything.
Post #644134 27th Sep 2022 5:28pm
garyRR
Nope, not possible.
You have to settle for pressing unlock on the remote or the doors unlock button below the hazard warning light switch. 2015 Range Rover Autobiography 4.4 SDV8
Post #644142 27th Sep 2022 6:49pm
JoshVogue94
Thanks for the reply mate, one of the only things I dislike about the car
Post #644146 27th Sep 2022 7:11pm
mjdronfield
If you mean when you unlock using a single press of the fob, you can change it with a diagnostic tool or similar.
If you mean when you are inside and pull the drivers door handle… don’t think so.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #644148 27th Sep 2022 7:34pm
mjdronfield
Ah, If it’s the unlock via fob, you can change the operation yourself, thought I’d posted something fairly recently…
https://www.fullfatrr.com/forum/topic64551.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644150 27th Sep 2022 7:40pm
garyRR
Turns out it is (now) possible, so long as you ask the right question:
It turns out you CAN get rid of one of the most annoying features on this car and have the doors unlock when you turn the engine off (note it might not work on pre 2010 cars).
So, the option doesn't appear in the standard CCF list so at some point you must have been given access to the entire CCF list.
After asking GAP again but this time to be granted access to the full CCF catalogue, sure enough, the option is hidden in there.
So, anyone wanting this and with an IID needs to write to GAP and request the access then, your CCF list will appear with this new option (basically the entire catalogue and not tested to make sure it does or doesnt work on your model so, be extra careful touching anything in here):
Then perform a search because there's hundreds of values in the catalogue. Select this one:
Change to Enabled and follow the procedure.
Warning to anyone who hasn't done a CCF change before, frightening things happen. Don't worry. Don't disconnect the tool or let the phone sleep whilst performing all the actions. Once completed, you will get lots of ECU errors on the driver display. Turn the ignition off, lock the car and leave it for 2 or 3 minutes so all ECUs go to sleep. Return and turn on the ignition, reconnect the IID and clear all fault codes and then use the car as normal. You'll need to set things like the clock, audio settings, speed warning, forward alert etc again.
The 'door unlock at engine off' feature seems to be quite clever when I tested it. It will only unlock the doors if they were previously locked by the 'drive away locking' feature. If you locked the doors manually with the dash button, when you turn the engine off, it knows this and keeps the doors locked for you. Very clever! 2015 Range Rover Autobiography 4.4 SDV8
Post #644872 5th Oct 2022 11:54pm
JoshVogue94
That's for the update on this mate think I'm going to have to get myself a GAP IID
Post #644888 6th Oct 2022 8:57am
Ian Donkin
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Very late to the party on this one, but I have to say this is the most pleasing change that I've been able to enable so far on our 2011 L322.
Patrick was super-obliging with enabling all the CCF access on my GAP tool and bingo - we now have doors that unlock when the engine is turned off.
Happy days! 2011 Range Rover Vogue SE 4.4 TDv8
Post #695522 4th Jul 2024 2:07pm
JayGee
I'm trying to think of reasons why this may not be desirable but can't think of any ouside some far fetched security / crime situation. 2012 TDV8 Vogue (L322)
Post #695524 4th Jul 2024 3:20pm
Ian Donkin
I'm with you on this, albeit I tend to be aware of my surroundings before switching off.
I will experiment with the locking options to see if I find the same as garyRR in that if locked with the central switch, it won't auto unlock... This could cover those rare scenarios where I am more conscious of potential dangers whilst driving although rural Surrey is generally a safe place...
It is a super pleasing, if simple, configuration change though! 2011 Range Rover Vogue SE 4.4 TDv8
Post #695525 4th Jul 2024 3:28pm
garyRR
It worked ideally on my car I.e. if I had intervened during the ignition cycle, it wouldn't auto unlock, as the BCM logic must tell it to cancel that action in that scenario.
But that was on a 2011, with a much newer BCM than on a 2004. 2015 Range Rover Autobiography 4.4 SDV8
Post #695526 4th Jul 2024 3:31pm
