Home > Maintenance & Mods (L405) > How much transmission oil needed on change
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys just had a transmission oil change done today on my L405 4.4 SDV8 I was advised to buy 8 litres of transmission fluid but isn’t this only if doing a mega flush through a machine the job only needed 5 litres of fluid is this right or has the gearbox been under filled?
Cheers
J Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #644230 28th Sep 2022 7:33pm
knwatkins
A single drop from the gearbox and you will drain bang on 3 litres. I did a quadruple drop/refill when I did mine on the driveway. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #644235 28th Sep 2022 8:43pm
jaysta10k
Hi Kev what do you mean by a quadruple drop exactly.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #644238 28th Sep 2022 9:05pm
knwatkins
When you drain the gearbox oil via the drain plug, you are only able to drain a proportion of it (3 litres) because the majority of it is held within the torque converter. By doing multiple drain and refill cycles, priming the gearbox in between, you will progressively be diluting the old oil with new, thereby refreshing it.
See my post near the bottom of the first page of my thread here... https://www.fullfatrr.com/forum/topic57338.html
Any questions, please shout Thumbs Up Kev
Post #644240 28th Sep 2022 9:28pm
caymanblack
If the gearbox oil is changed at the MD do they do what you have done kn and change it multiple times, I wonder.
Post #644300 29th Sep 2022 12:01pm
jaysta10k
Okay thanks for that appreciate it Kev Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #644303 29th Sep 2022 12:47pm
knwatkins
I would imagine they would flush with a flushing machine. Kev
Post #644322 29th Sep 2022 5:44pm
Phoenix
The dealer will follow the workshop instruction - essentially, drop oil, remove sump pan & filter, fit new sump pan & filter, replenish oil & correct level. No flushing involved.
Post #644329 29th Sep 2022 6:12pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
5L is what mine used. I bought 7 just in case. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #644348 29th Sep 2022 9:43pm
Phoenix
With a new sump & filter, mine took 5.6l @30deg. C. on a level ramp, the last 0.6l went in a couple of weeks later when I had chance to level check at the correct temperature. If you are not dropping the transmission sump, then the refill quantity will be lower.
Post #644350 29th Sep 2022 10:02pm
caymanblack
In that case they have not replaced all of the old oil as Kev has pointed out.
Post #647302 4th Nov 2022 2:39pm
