![]() | Home > Maintenance & Mods (L405) > How much transmission oil needed on change |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
A single drop from the gearbox and you will drain bang on 3 litres. I did a quadruple drop/refill when I did mine on the driveway. Kev
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi Kev what do you mean by a quadruple drop exactly.
When you drain the gearbox oil via the drain plug, you are only able to drain a proportion of it (3 litres) because the majority of it is held within the torque converter. By doing multiple drain and refill cycles, priming the gearbox in between, you will progressively be diluting the old oil with new, thereby refreshing it.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1170 ![]() ![]() ![]() |
If the gearbox oil is changed at the MD do they do what you have done kn and change it multiple times, I wonder. |
Okay thanks for that appreciate it Kev Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
I would imagine they would flush with a flushing machine. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
The dealer will follow the workshop instruction - essentially, drop oil, remove sump pan & filter, fit new sump pan & filter, replenish oil & correct level. No flushing involved. |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 255 ![]() ![]() ![]() |
5L is what mine used. I bought 7 just in case. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
With a new sump & filter, mine took 5.6l @30deg. C. on a level ramp, the last 0.6l went in a couple of weeks later when I had chance to level check at the correct temperature. If you are not dropping the transmission sump, then the refill quantity will be lower. |
In that case they have not replaced all of the old oil as Kev has pointed out. |
