Home > Wheels & Tyres > "L322 fitted with L405 wheels" thread
Page 18 of 20 <123 ... 17 181920>
BenRK
Seriouslthinkingaboutit wrote:
Apologise for the daft question
How do you know what are the right pressures to use given these are non standard wheels
I've been pondering what's right for mine - standard L322 20" wheels but fitted with (not my choice) 275/40 tyres
Thanks
Douglas
I don't exactly but I've got them all at 40psi. That's the pressure I ran my 20s and they were ok so thought it a good starting point for these
Post #631499 13th May 2022 10:58am
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Thanks Ben 2007 4.2SC Buckingham Blue
https://www.fullfatrr.com/forum/topic63319.html
Post #631500 13th May 2022 11:01am
Buckie1967
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Buckingham Blue
Just got my L322 but doing a bit of research I think the wheels are Style 1065 20″ 12 Spoke Alloy Wheels from the L405 range.
Post #637894 26th Jul 2022 8:07pm
AMV
2011 Range Rover Vogue TDV8 Santorini Black
they looks amazing, so the 20" 1065 style will fit a TDV8 4.4 without issues? Thumbs Up if I remember wheel the OEM 20" L322 had a different ET Rolling Eyes Santorini Black RR Vogue 4.4 TDV8
Post #644259 28th Sep 2022 11:00pm
Buckie1967
Yes the original 20" L322 has an ET 58 offset. These on my L322 are ET 47. (In very basic terms the lower the number the more the wheels stick out, in this case it is only an extra 11mm)
The other difference is I am using a 255/55/20 tyre which is the standard size on the L405 as opposed to the regular 255/50/20 tyre that is standard with the L322. I doubt it will affect the speedo enough to matter and the theory is there will be slightly more cushioning from the tyre however I doubt it will be enough to really notice.
Post #644260 28th Sep 2022 11:14pm
JayGee
Your speedo can read slightly under the actual road speed with 255/55 R20 tyres but you can adjust this using the GAP IID tool. 2012 TDV8 Vogue (L322)
Post #644269 29th Sep 2022 7:41am
AMV
Thank you gents, do you know if L405 tpms work with l322? Santorini Black RR Vogue 4.4 TDV8
Post #644288 29th Sep 2022 9:39am
ttrw2
Here's L322 on L405 wheels, with 255/55r20 Pirelli All Seasons
Post #644362 30th Sep 2022 7:08am
Gremlin500
@ttrw2,
What a nice car! -Yours?
I’m not normally a fan of brown, but that looks really smart and as if it’s just driven out of a dealer showroon on its original wheels, very tasteful Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #644396 30th Sep 2022 11:54am
JayGee
The L322 looks better on the 255/55 R20 IMO and I also run it 12mm lower via the GAP IID tool to keep the 'ride height' the same
Post #644404 30th Sep 2022 1:32pm
Andy
Has anyone fitted these 21” to an L322? Thinking about getting these to replace my cracked 22” (of which I now have two).
 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #652474 4th Jan 2023 1:05am
i havnt but i know they will fit ok . ... - .- -.
Post #652477 4th Jan 2023 8:08am
Andy
Thanks Stan. These are £700 so I think I’ll go and get them today. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #652486 4th Jan 2023 10:45am
Andy
So here’s ours with the L494 21” with the standard Pirelli Scorpions.
It does drive a lot better than the 22” we had. Nice offset as well as though they were meant for the car. By comparison I think the original 20” are a bit too skinny.
Post #653778 17th Jan 2023 11:04am
looks like a good buy..very nice Thumbs Up ... - .- -.
Post #653781 17th Jan 2023 11:26am
