Home > Technical (L322) > Central locking auto unlock
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Anyone know if it's possible to code auto unlock with ignition off?
It's so annoying having to push the button to unlock every time. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #644669 3rd Oct 2022 5:20pm
Phoenix
I've done it with a simple timer circuit triggering a relay across the unlock switch - 08MY
Post #644671 3rd Oct 2022 5:29pm
if you have suto lock on then when you stop you can double pull the door lever to open the door..
or you switch off auto lock.. ... - .- -.
Post #644672 3rd Oct 2022 5:41pm
garyRR
Re: Central locking auto unlock
No, it's not possible without setting up your own relay. 2015 Range Rover Autobiography 4.4 SDV8
Post #644673 3rd Oct 2022 5:46pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Its in the menu on the screen on my 2011 m.y 4.4 TDV8. Option to switch it on or off. Steering wheel right hand menu group.
Post #644680 3rd Oct 2022 7:27pm
garyRR
Yes, door lock but not unlock on ignition off. 2015 Range Rover Autobiography 4.4 SDV8
Post #644681 3rd Oct 2022 7:29pm
jagracer
Sorry, I thought you wanted to avoid the double pull. Landrover programs the doors to unlock on impact, I found that as I have had trouble with my wife's FL2 key, and auto unlocking during the night and dropping the windows. A new key was the answer.
Post #644686 3rd Oct 2022 8:03pm
Ffrr-lover
It is possible with an IIDTool… it’s one of the extra setting in the cff settings. I can’t recall which it is offhand, but I’ve done it and works without issue. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #644699 3rd Oct 2022 10:14pm
garyRR
I've checked directly with GAP before who said it's not possible. Unless you know a secret setting they don't? Bow down 2015 Range Rover Autobiography 4.4 SDV8
Post #644700 3rd Oct 2022 10:22pm
Ffrr-lover
It’s definitely possible… I have it enabled on my car.
I’ll take a look later to find that setting and will report back Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #644707 4th Oct 2022 5:29am
Ffrr-lover
Found it…
It’s under the untested CCF section, and is called “Door unlock at engine off”.
Again, I have drive away locking enabled and this setting enabled and have had no issues with this. As it says, when I press the start/stop button all doors unlock and require the one pull to open.
If it matters, mine is an MY12.
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #644739 4th Oct 2022 12:15pm
garyRR
Just to check the build version on your IID?
I will go and check on mine. 2015 Range Rover Autobiography 4.4 SDV8
Post #644745 4th Oct 2022 1:10pm
Ffrr-lover
I’m on 2765 I believe.
It’s a version which allows DPF regens, but I’d made the change with a previous version. That was the latest “normal” version at the time. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #644755 4th Oct 2022 3:11pm
garyRR
I assume you've been a previous Beta tester or had the full CCF granted to you?
The option is greyed out for me.
Post #644757 4th Oct 2022 3:15pm
Ffrr-lover
Ah yes!
As soon as I read that I recalled requesting access to the full CCF!
I found the email I sent where I asked for access to it. Had a very quick response saying they enabled it and to update my IIDTool… along with a “be careful” warning.
I’ve only changed that setting, and the double lock feature, as I hadn’t found any other validated changed I was interested in. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #644782 4th Oct 2022 6:40pm
