|  | Home > Technical (L322) > Central locking auto unlock |
| Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454      |
 Anyone know if it's possible to code auto unlock with ignition off?
|  3rd Oct 2022 5:20pm |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631    | I've done it with a simple timer circuit triggering a relay across the unlock switch - 08MY | ||
|  3rd Oct 2022 5:29pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | if you have suto lock on then when you stop you can double pull the door lever to open the door..
|  3rd Oct 2022 5:41pm |
| jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 124      | Its in the menu on the screen on my 2011 m.y 4.4 TDV8. Option to switch it on or off. Steering wheel right hand menu group. | ||
|  3rd Oct 2022 7:27pm |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494    | Yes, door lock but not unlock on ignition off. 2015 Range Rover Autobiography 4.4 SDV8 | ||
|  3rd Oct 2022 7:29pm |
| jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 124      | Sorry, I thought you wanted to avoid the double pull. Landrover programs the doors to unlock on impact, I found that as I have had trouble with my wife's FL2 key, and auto unlocking during the night and dropping the windows. A new key was the answer. | ||
|  3rd Oct 2022 8:03pm |
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640      | It is possible with an IIDTool… it’s one of the extra setting in the cff settings. I can’t recall which it is offhand, but I’ve done it and works without issue. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
|  3rd Oct 2022 10:14pm |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494    | I've checked directly with GAP before who said it's not possible. Unless you know a secret setting they don't?  | ||
|  3rd Oct 2022 10:22pm |
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640      | It’s definitely possible… I have it enabled on my car.
|  4th Oct 2022 5:29am |
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640      | Found it…
|  4th Oct 2022 12:15pm |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494    | Just to check the build version on your IID?
|  4th Oct 2022 1:10pm |
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640      | I’m on 2765 I believe.
|  4th Oct 2022 3:11pm |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494    | I assume you've been a previous Beta tester or had the full CCF granted to you?
|  4th Oct 2022 3:15pm |
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640      | Ah yes!
|  4th Oct 2022 6:40pm |
| Posting Rules
