|  | Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal |
| telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140      | Well there were a few issues at work there but yes   | ||
|  6th Oct 2022 6:47pm |
| telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140      | Hi Paul and congrats on the new purchase.  I would suggest reading this thread in full for a full answer or at least the last 5 pages or so.  Long story short, yes. Cam
|  9th Oct 2022 1:02am |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | Hesitancy and lack of power are not normal so fix these faults before thinking about a remap   | ||
|  9th Oct 2022 3:10am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Clean the MAP sensor for starters - it can make a huge difference. Use a spray cleaner. However the donut could be very clogged and cleaning it (after removal) is a messy job. | ||
|  9th Oct 2022 4:07am |
| telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140      | It doesn't sound like he reckons there's a fault here, more that he doesn't like the engine response which in the context of this thread is quite relevant.  Of course common issues can cause problems in this area, but and I could be wrong, it doesn't sound to me like Paul thinks he has anything more than standard characteristics he's not keen on... Cam
|  9th Oct 2022 1:16pm |
| Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 66      |
 Since you don't believe my fairytale story about the big bad EGR-valve, have a look at what mr. Wikipedia has to say about it: https://en.wikipedia.org/wiki/Exhaust_gas_...el_engines EGR-valves are bad for engines, and especially diesel engines. Their sole purpose is to comply with emission requirements, e.g. Euro 2, 3, 4, 5 etc. | ||
|  10th Oct 2022 1:05am |
| Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 66      | In diesel engines in particular, EGR systems come with serious drawbacks, one of which is a reduction in engine longevity. For example, because the EGR system routes exhaust gas directly back into the cylinder intake without any form of filtration, this exhaust gas contains carbon particulates. And, because these tiny particles are abrasive, the recirculation of this material back into the cylinder increases engine wear. This is so because these carbon particles will blow by the piston rings (causing piston-cylinder-interface wear in the process) and then end up in the crankcase oil, where they will cause further wear throughout the engine simply because their tiny size passes through typical oil filters. This enables them to be recirculated indefinitely (until the next oil change takes place).[9]
|  10th Oct 2022 1:16am |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464      | With all of this extra wear, it seems odd that new engines are seemingly not needed on a regular basis. My Sprinter is now at over 500,000 miles, My Allroad 310,000+ and my Touareg over 280,000 miles, all still running well, not using oil and have EGR system in tact.
|  10th Oct 2022 3:25am |
| Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 66      | It's from the Wikipedia article. | ||
|  10th Oct 2022 3:53am |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464      | Thanks. BMW i3 Electric Car
|  10th Oct 2022 4:47am |
| jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194      | New type or EGRs takes exhaust after DPF, so its much cleaner and free from soot particles. | ||
|  10th Oct 2022 8:30am |
 Hesitancy is not a standard feature and sounds like a fault to me. Map sensor blocked, air leak etc. The EGR closes when you open the throttle so will only create hesitancy if it's faulty. DPF ( blocked or otherwise) will only restrict flow at high gasflow conditions and not at low speed so again deleting this will not solve hesitancy. 2012 TDV8 Vogue (L322) | ||
|  10th Oct 2022 8:36am |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | @faukstad - searching for a solution to a problem that for almost all TDV8 4.4 owners simply doesn't exist. Don't we have enough other issues to deal with? If I was TDV8 3.6 owner it would be a different story. 2012 TDV8 Vogue (L322) | ||
|  10th Oct 2022 8:51am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Mine's MAP sensor was well clogged with soot again after less than 2000 kms since it was last cleaned and the air inlet (donut) had accumulated another significant layer of soot and oily muck and the engine side of the butterfly too since it was all cleaned 4 years ago. An EGR-delete remap will occur shortly.
|  10th Oct 2022 10:02am |
| Posting Rules
