Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal
Page 11 of 17 <123 ... 101112 ... 151617>
GraemeS
Australia
jaguar3 wrote:
New type or EGRs takes exhaust after DPF, so its much cleaner and free from soot particles.
That should make a huge difference.
Post #645256 10th Oct 2022 11:06am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
As it's sensing manifold pressure, could it not be modified to have a short length of pipe to the sensor? That would remove the sensor from the polluted airflow. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #645257 10th Oct 2022 11:31am
GraemeS
Australia
A son used to have a Saab which had its MAP sensor mounted on the firewall, connected by thick-walled tubing.
Post #645259 10th Oct 2022 11:42am
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
JayGee wrote:
telly-addict wrote:
It doesn't sound like he reckons there's a fault here, more that he doesn't like the engine response which in the context of this thread is quite relevant. Of course common issues can cause problems in this area, but and I could be wrong, it doesn't sound to me like Paul thinks he has anything more than standard characteristics he's not keen on...
Hesitancy is not a standard feature and sounds like a fault to me. Map sensor blocked, air leak etc. The EGR closes when you open the throttle so will only create hesitancy if it's faulty. DPF ( blocked or otherwise) will only restrict flow at high gasflow conditions and not at low speed so again deleting this will not solve hesitancy.
From what I've heard actually it is. The standard LR mapping of the ECU adds in a certain amount of hesitancy to restrict rapid changes in acceleration in keeping with the luxury intent of the FFRR. This is reason enough for many to remap, to improve throttle response. As I said though, there are issues that can exacerbate this but they shouldn't automatically be assumed. Everyone has their own definition of response and hesitancy that depends largely on background/experience. Cam
2011 TDV8 Vogue in Stornoway Grey
Post #645264 10th Oct 2022 12:46pm
JayGee
Mine doesn't hesitate but I notice when it does as it's telling me the MAP sensor needs cleaning. 2012 TDV8 Vogue (L322)
Post #645268 10th Oct 2022 2:39pm
Faukstad
Norway 2012 Range Rover Autobiography TDV8 Santorini Black
JayGee wrote:
@faukstad - searching for a solution to a problem that for almost all TDV8 4.4 owners simply doesn't exist. Don't we have enough other issues to deal with? If I was TDV8 3.6 owner it would be a different story.
Can't argue with that one buddy... Razz
I'm very new to the 4.4, haven't owned mine for a year yet. So I can't say I'm a self-declared expert. Yet...
Love it to bits though, I can't imagine a better engine for the big Rango.
Mine's remapped though. just shy of 400 hp with 800 Nm of torque. It's borderline scary, and hesitation is the last word that comes to mind when I floor it.
I have a 2012 3.0 TDV6 sport as well, and that's been an absolute nightmare when it comes to EGRs...
Post #645272 10th Oct 2022 3:52pm
GraemeS
Australia
For those who have an EGR delete, was the throttle butterfly left fitted or removed? Also, do you know if the remap only prevented the EGR valve from opening during engine running or were fuelling tweaks included?
I've not read of the 4.4's buttefly being removed but certainly on the 2.7 TDV6, but I require mine's butterfly to stay fitted for my runaway protection.
The EGR delete that I'm persuing is mine's existing maps being UK modified but no other information at this time.
Post #645307 11th Oct 2022 4:12am
Faukstad
Does anyone know of (anyone) who makes a map that can be uploaded with the Gap IID tool?
I seem to recall I've read about that being possible with other models/engines.
Post #645308 11th Oct 2022 4:15am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
How "strong" is map sensor? Is it possible to damage it when cleaning with compressed air for example?
Post #645309 11th Oct 2022 4:59am
kevinp
I use carburettor cleaner first and then an air line at a distance to dry it out. I wouldn't use an air line close up.
I damaged a map sensor on my other car by trying to gently pick out the dirt and punctured the diaphragm inside.
Just keep spraying the cleaner in and gently blow the crud out bit by bit.
Post #645310 11th Oct 2022 5:57am
GraemeS
Australia
I use spray contact cleaner.
Post #645311 11th Oct 2022 6:22am
GraemeS
Australia
It wasn't that long ago that GAP advised that their tool could not upgrade the L322 4.4 TDV8 PCM in regards to applying a later LR update, not a map update.
The Atric Powergate user tool can write maps via the OBD port that have been loaded onto the tool by the Atric Powergate programming tool. I'm waiting to hear whether the user tool can read the current map file via the OBD port as the 1st step to having an EGR-deleted version produced remotely, but I suspect that the PCM will have to be removed and bench-read. I'm 6 hours travel away from the workshop and would have to stay overnight to have the PCM updated in the morning so I'm interested in what the Atric user tool can do.
Post #645312 11th Oct 2022 6:34am
JayGee
I use brake cleaner as the solvent dissolves the oil and the directional nozzle creates enough force to blow out the soot. Poor design as it's location is in the EGR flow but at least it's an easy enough job to do. 2012 TDV8 Vogue (L322)
Post #645321 11th Oct 2022 9:19am
telly-addict
Not true, there is a relatively common fault with the 4.4 TDV8 EGR temp sensor mounted in the left exhaust manifold causing the P040d fault code. The sensor is not easy to change given its location and prompted me to delete the EGR while remapping rather than tackle the sensor. Cam
Post #645330 11th Oct 2022 10:45am
telly-addict
Very easy to damage the diaphragm with compressed air. As others have said, use brake cleaner to clean out and resist temptation to use a tool to pick out. Thumbs Up Cam
Post #645331 11th Oct 2022 10:47am
