|  | Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464      | As it's sensing manifold pressure, could it not be modified to have a short length of pipe to the sensor? That would remove the sensor from the polluted airflow. BMW i3 Electric Car
|  10th Oct 2022 10:31am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | A son used to have a Saab which had its MAP sensor mounted on the firewall, connected by thick-walled tubing. | ||
|  10th Oct 2022 10:42am |
| telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140      |
 From what I've heard actually it is. The standard LR mapping of the ECU adds in a certain amount of hesitancy to restrict rapid changes in acceleration in keeping with the luxury intent of the FFRR. This is reason enough for many to remap, to improve throttle response. As I said though, there are issues that can exacerbate this but they shouldn't automatically be assumed. Everyone has their own definition of response and hesitancy that depends largely on background/experience. Cam 2011 TDV8 Vogue in Stornoway Grey | ||
|  10th Oct 2022 11:46am |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | Mine doesn't hesitate but I notice when it does as it's telling me the MAP sensor needs cleaning. 2012 TDV8 Vogue (L322) | ||
|  10th Oct 2022 1:39pm |
| Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 66      |
 Can't argue with that one buddy...   I'm very new to the 4.4, haven't owned mine for a year yet. So I can't say I'm a self-declared expert. Yet... Love it to bits though, I can't imagine a better engine for the big Rango. Mine's remapped though. just shy of 400 hp with 800 Nm of torque. It's borderline scary, and hesitation is the last word that comes to mind when I floor it. I have a 2012 3.0 TDV6 sport as well, and that's been an absolute nightmare when it comes to EGRs... | ||
|  10th Oct 2022 2:52pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | For those who have an EGR delete, was the throttle butterfly left fitted or removed?  Also, do you know if the remap only prevented the EGR valve from opening during engine running or were fuelling tweaks included?
|  11th Oct 2022 3:12am |
| Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 66      | Does anyone know of (anyone) who makes a map that can be uploaded with the Gap IID tool?
|  11th Oct 2022 3:15am |
| jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194      | How "strong" is map sensor? Is it possible to damage it when cleaning with compressed air for example? | ||
|  11th Oct 2022 3:59am |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | I use carburettor cleaner first and then an air line at a distance to dry it out. I wouldn't use an air line close up.
|  11th Oct 2022 4:57am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | I use spray contact cleaner. | ||
|  11th Oct 2022 5:22am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | It wasn't that long ago that GAP advised that their tool could not upgrade the L322 4.4 TDV8 PCM in regards to applying a later LR update, not a map update.
|  11th Oct 2022 5:34am |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | I use brake cleaner as the solvent dissolves the oil and the directional nozzle creates enough force to blow out the soot. Poor design as it's location is in the EGR flow but at least it's an easy enough job to do. 2012 TDV8 Vogue (L322) | ||
|  11th Oct 2022 8:19am |
 Not true, there is a relatively common fault with the 4.4 TDV8 EGR temp sensor mounted in the left exhaust manifold causing the P040d fault code. The sensor is not easy to change given its location and prompted me to delete the EGR while remapping rather than tackle the sensor. Cam 2011 TDV8 Vogue in Stornoway Grey | ||
|  11th Oct 2022 9:45am |
 Very easy to damage the diaphragm with compressed air. As others have said, use brake cleaner to clean out and resist temptation to use a tool to pick out.  Cam 2011 TDV8 Vogue in Stornoway Grey | ||
|  11th Oct 2022 9:47am |
| Posting Rules
