![]() | Home > Technical (L322) > Icarsoft DPF regeneration |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 56 ![]() ![]() ![]() |
Hi mate it was a split in one of the intake pipes that has caused the build up of soot |
Just an update, have given up on the icarsoft and bought the GAP IID. Forced regenerated the car and then cleared the codes and all back to normal with the red dpf full warning gone. Took the soot content from 33.4g to 0.6g. Wish I'd just bought the IID tool at the start instead of wasting money on the icarsoft. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Ditto. I bought an icarsoft being a tight northerner and then realised its |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
Can anyone list the things which will stop IID from doing a forced regen please?
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1776 ![]() ![]() ![]() |
Which versions of the iCarSoft are we talking about above? 1, 2, or 3?
That DTC will prevent a regen (correlation error) not be set due to one being required. Check the differential pressure with ign. on, engine off - should be pretty close to 0kpa, anything else can point to blocked pipes, condensate in the sensor or a faulty sensor, all of which are 'Tom Jones' problems. |
Hi, just checked and the "Particulate filter differential pressure - measured" is reading N/A whether the engine is running, or just ignition on. Am I looking at the correct live value?
ddcotbg Member Since: 04 Jul 2018 Location: Liverpool Posts: 3 ![]() ![]() ![]() |
This sounds promising. I just got an iCarsoft v2.0 and have the red triangle - wondering how to clear it. Do you go through the options to select 'force regen', then take it on a drive in limp home mode to clear it, or do you do it while it is standing on the drive, just keeping the revs up? Will it clear in limp mode? Ta |
Only the voltage shows as a live value. Use the Workshop manual downloadable from the Wiki to tell you what the voltages mean 2012 TDV8 Vogue (L322) |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 54 ![]() ![]() ![]() |
hi you must be driving to force regen, the carsoft will tell you what you should be doing to get it going been a long time since needed to do it
Nice one. That's really helpful. Will limp it onto the motorway later and give it a go. Thanks again. |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
Good luck - interested to know how you get on - please update us on here?
