![]() | Home > Technical (L322) > Having my leg pulled surely ? |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I can't comment on all your issues. The Shunt aka 'Lurch' as known to X5 owners, is a real pain and well documented on the web. You don't mention the age or model of the FFRR. I sold my X5 because i couldn't live with the poor gearbox and didn't fancy spending a fortune on a rebuild/fishing trip. Best of luck Ian |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
TDV8 07 43,000 miles |
I would imagine the gearbox is different, i'm not sure. If its under warranty dont be fobbed off. Ian |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
the brake pedal switch or one of them does control all of those functions in a round about way so yes its correct |
I also noticed the brake pedal switch causing all kinds of warnings when it breaks in the forums, so again the mechanic could be right. That is modern electronics for you, one tiny little switch fails and the whole thing is in ruins. Must be all the bits and bytes getting lost in cyberspace |
You forgot the FBH. No NOT the fuel burning heater ![]() |
To hopefully add some value to the OP, I had the same lurch on the 2 -> downshift, which was actually a nasty bang if you were trickling up to a junction and decided to go for a gap. This was on my D3 V8. The cure for me was 3 things.
If you examine each system in detail (=read the manual), you'll see that each system has some sort of input from the brake light switch. Yes our very electronic cars are a long shot off the primitive mechanical vehicles we used to ride in - and that allows us to have power levels that used to be only supercar territory, consumption that used to require driving an econobox, safety that could not be achieved back then (DSC, SRS,etc), GPS guidance, etc, etc, etc
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
dosent suprise me, I had a similar array of errors over a few weeks, and finally ended up being a £17 speed sensor wire for the ABS
Sorry. Stupid humor. ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
shirley not steve... i like stupid humour.. ![]() |
