Home > Maintenance & Mods (L322) > Deployable Side Steps fitted… roof button goes where?
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Mine looks quite ok.
Post #646449 25th Oct 2022 8:00am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Mine doesnt quite sit right. The thin plastic allows the two ends to flex, therefore sit slightly proud in places.
Not really a massive eyesore so not in a rush to fix it… but I know its there so it bugs me.
 Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #646478 25th Oct 2022 12:49pm
cass
You could hide the switch behind an uncut vent panel, If you did need to switch off the steps before you get the right bit you just need to select "Mud Ruts" on the terrain control and it stops them operating?
Post #646572 26th Oct 2022 9:31am
just a thought,
you dont 'have' to put the switch in the roof panel...it could go anywhere, front console/inside arm rest cubby/right of steering wheel/???? ... - .- -.
Post #646573 26th Oct 2022 9:45am
Ffrr-lover
Cheers cass and Stan for your thoughts. The button is in place and tbh I haven’t really noticed the poor fit, so will leave it as is… but will continue to keep an eye out for its proper replacement.
They are both good shouts and may benefit others in the future Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #646837 30th Oct 2022 8:21am
jimmie
you should do a little bigger hole the inner parts are to tight and cover bends itself outside
Post #646841 30th Oct 2022 8:55am
Ffrr-lover
Do you mean the hole i cut for the button?
I found that the clips were pushing the ends down as the middle section was too weak. I may give that a go however… but am wary that I am close to them breaking. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #646846 30th Oct 2022 10:02am
jimmie
you need to do more space for this metal clips. sides leave as is.
Post #646848 30th Oct 2022 10:09am
