Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal
Page 12 of 17 <123 ... 111213 ... 151617>
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
GraemeS wrote:
For those who have an EGR delete, was the throttle butterfly left fitted or removed? Also, do you know if the remap only prevented the EGR valve from opening during engine running or were fuelling tweaks included?
My car was left unmolested except for an egr blanking plate. Mine also had a power boost remap as well as egr delete because why not Cool
I cannot say what they do to remove the egr from the map, but know they do something to stop the errors popping up if blanked. I was told the map does stop the egr from operating so the blanking plate isn’t necessarily needed… but decided to get one fitted just in cast the egr was gunked up and not properly closed. Maybe unnecessary, but no harm and simple to remove. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #645341 11th Oct 2022 12:51pm
Ffrr-lover
Faukstad wrote:
Does anyone know of (anyone) who makes a map that can be uploaded with the Gap IID tool?
I seem to recall I've read about that being possible with other models/engines.
I believe it’s not possible. My ECU was removed and updated on the bench. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645342 11th Oct 2022 12:53pm
Ffrr-lover
jaguar3 wrote:
How "strong" is map sensor? Is it possible to damage it when cleaning with compressed air for example?
I’m curious… if the diaphragm was damaged, would the car know? Would it generate an alert?
I’ve only ever used a cleaning spray on mine at least… but who knows from a previous owner? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645343 11th Oct 2022 12:55pm
JayGee
It would throw a fault code if damaged as the ECU would know if a pressure reading was outside expected parameters for RPM, load etc and it throws a code if disconnected straight away. 2012 TDV8 Vogue (L322)
Post #645350 11th Oct 2022 1:19pm
GraemeS
Australia
Thanks FFRR-lover for your comments - much appreciated.
I found a local tuner who will do the re-map of an evening to get the updated map from the UK while I wait. He recommends the economy upgrade which brings the power and torque specs to about the same as the L405 4.4 for the same price, which I've decided to get. The ecu has to be bench-updated.
I'll install a blanking plate in case of future valve leakage once I'm happy with the update and at the same time will remove the section of pipe protruding into the airstream.
Post #645402 11th Oct 2022 9:22pm
kevinp
When I punctured mine, accidently , on my previous car, the engine would start but had no power. It would hardly rev.
Post #645405 11th Oct 2022 10:43pm
JayGee
Does yours have a DPF? as I thought these were not fitted for the Australian market on these engines? 2012 TDV8 Vogue (L322)
Post #645417 12th Oct 2022 9:47am
GraemeS
Australia
No DPF on mine but possibly on any vehicle that ended-up here that was built for another country.
Post #645421 12th Oct 2022 10:47am
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
@Telly-addict and @Ffrr-lover have you guys looked at exhaust gas temperature sensors readings after EGR-delete? Especially B1S2 and B1S3. Would be valuable information. I have pulled lots of data from my properly working OEM system for comparsion. Would be very interesting. I'm planning on deleting EGR too to improve engine health and longevity.
Post #646990 31st Oct 2022 6:59pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
I can't say I have no. I'll try and have a look when I next get the chance but I'm pretty tied up with customer cars atm. Cam
2011 TDV8 Vogue in Stornoway Grey
Post #646997 31st Oct 2022 8:00pm
kokamagi
Thanks, would be great 🙂
Post #647001 31st Oct 2022 8:28pm
GraemeS
Australia
Mine had its EGR mapped out coupled with an economy tune supposedly taking power to a little over 250kW this evening. First impressions are that it is nicely responsive off the mark, upshifts occur on less throttle and at lower revs and it still idles through mud at 1000 rpm in either normal or GGS just as it did before as far as I can tell. Economy around the streets is improved and 100 kph cruising in undulating terrain might have improved a little, but I look forward to longer term usage.
Post #647190 3rd Nov 2022 10:54am
kokamagi
@GraemeS same request to you then. If you have an IIDTool or any other interface for reading live values, maybe you can pull live data from exhaust temp sensors say at highway cruising speeds, now after EGR delete?
Cheers
Keijo
Post #647191 3rd Nov 2022 11:12am
GraemeS
Australia
The only exhaust system temperature sensor on mine, which doesn't have a DPF, is in the left manifold and it doesn't work. The temp sensor in the EGR valve won't get any recirculated exhaust gases.
Post #647192 3rd Nov 2022 11:25am
kokamagi
Oh, sorry, didn't know the system build-up for non-DPF vehicle. So you don't have any temp. sensors directly before or after the catalytic converter?
Cheers
Keijo
Post #647194 3rd Nov 2022 11:41am
