![]() | Home > Maintenance & Mods (L322) > Brake calipers improvement |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 922 ![]() ![]() ![]() |
are these the right ones ?
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
If the nipple has corroded inside that would suggest the brake fluid maintenance has been overlooked a few times. Christian.
maybe, but let me get the frigging M10 bolts out first ![]() when I do get them out I will be looking out for some rubber covers to give them a little more protection when I put new ones in
and I guess Titanium is no better ?? I will need to buy 4 x new nipple bolts anyway, so are you saying that there is no material that will help slow down the corrosion, if so this is really awful design on the part of JLR and Brembo ![]() |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1730 ![]() ![]() ![]() |
True, in the prescence of water but there shouldn’t be any water in your brake fluid, if changed regularly. There’s no option of alloy nipples of course, they’d just snap like carrots ![]() I sparingly use copper grease on mine, knowing that the thread is outboard of the nipple seat, so fluid and grease should never mingle other than when bleeding, when the flow is away from the calipers anyway. ![]() EDIT: Sorry it wasn’t copper grease, I used PTFE tape! (on new nipples/new brakes). I don’t think its a big deal, if used sparingly, anything that provides a barrier will prevent corrosion, the threads are outboard of the brake fluid, so contamination of fluid is highly unlikely in operation, only when bleeding when the old fluid is flushing any particles out of the caliper. “If it ain’t broke, don’t fix it” -where’s the fun in that? Last edited by Gremlin500 on 1st Nov 2022 5:26pm. Edited 2 times in total |
Covers won't make any difference - it's the steel of the nipples interfacing with the alloy of the callipers that causes the problem. Maybe look for some lightweight 'racing' nipples. Some alloys of Aluminium are very strong and are used in aerospace applications so well up to the job. Red Rubber grease is safe to use on the threads as it's designed to contact brake fluid. 2012 TDV8 Vogue (L322) |
these Titanium ones sound the answer - anyone used them - here is the sales blurb
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 531 ![]() ![]() |
Agree - first thing I thought of when I saw this thread. Stainless steel bleed nipples in a steel caliper [EDIT - or alloy in the case of the fronts] will induce bi-metallic corrosion. In reality, this shouldn't be a massive issue, so long as they're used (i.e. opened) occasionally. But if left for a couple of years, there could a hell of a fight trying to shift them. If you do go ahead and use them, then as suggested by others, I'd cover the threads with a light coat of ceramic brake grease or similar to act as a buffer between the two dissimilar metals. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) Last edited by D3Jon on 1st Nov 2022 10:33pm. Edited 1 time in total |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8618 ![]() ![]() ![]() |
D3 Jon, it's worse than that, it's steel, stainless or otherwise into alloy..!!
You shouldn't use copper grease on alloy callipers, it's just adding another metal into the mix and will promote corrosion... Don't know if this is compatible with brake fluid but seeing as fluid only tends to flow out of a bleed nipple I'd use some of this... Used it on the boat and it is good... ![]() https://www.force4.co.uk/item/Harken/Tef-G...-Paste/CM8 Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Thanks, good point and just realised that myself Pete. |
See my update above….. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Not a bad shout - a thin layer of PTFE tape sounds like it should do the job (So long as it doesn't get near the sealing face of the bleed nipple)! Might also help with vacuum bleeding - one thing I always have issues with with a vacuum bleeder is outside air sucking past the threads of the opened bleed nipple. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
@D3Jon:
Goodridge stainless steel braided flexible brake hoses have PTFE liners. 2012 TDV8 Vogue (L322) |
