![]() | Home > Technical (L322) > 4.4 tdv8 hesitation at 80 mph'ish |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 849 ![]() ![]() |
Comment from Marsie that the 8 speed gearbox cannot be flushed.
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 340 ![]() ![]() ![]() |
Rambles
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8777 ![]() ![]() ![]() |
trickier to flush the 8 speed as there is a thermostat in the oil cooler lines so that needs to be open to flush using the cooler lines as they do on the 6 sp and 5 sp, its not electronical so would need actua fluidl heat to open but then as soon as you put cool oil in it will shut.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
8 speed can be Megaflush. Quite a few places do it now. Mine being done by Bodsy on my drive in 2 weeks |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 337 ![]() ![]() ![]() |
If the IID tool shows that a SW upgrade is available when scanned you should be able to get it from GAP - or at least ask them P525
Thanks M@tt. I’ll have a look tomorrow. I believe the upgrade is located in the PCM section |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Millerj90, did you find anything more out about this? I'd be interested to know if mine has it as it does seem to suffer from hesitation. 2010 4.4 TDV8 Vogue SE |
Kooky
I’ve been i. Touch wth the great guysfrom GAP. Patrick has informed me that the PCM reflash via the IID tool is unlikely to clear the problems mentioned in LTB00454v2 - Engine Hesitation |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
you'll have get a dealer to sort it then.. |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
Can you guys, who have done the PCM update by LTB00454v2, share your PCM (or ECM) data? I want to know if mine has been done, so need comparsion data. I've also felt a juddering few times, while cruising at highway speeds over 110 km/h. Really worrysome feeling.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3361 ![]() ![]() ![]() |
Had my box updated last month;
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2756 ![]() ![]() |
Mine was updated supposedly to the latest level for a non-DPF engine June 2020.
