Home > Maintenance & Mods (L322) > Third brake light
Fox889
Third brake light
Strange one for you:
Third brake light was only working 50% of the LED’s plus, while switched off & locked up in pitch dark, you could see a slight glow from the 50% working LED’s.
Changed the unit for a genuine LR one, all working brilliantly…….but…..again when shut down & in the dark, there’s a very dim glow from all of the LED’s. You have to get close to see it, it’s not blatant but it’s there.
Any ideas? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #648117 15th Nov 2022 9:21am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Try checking again 30 minutes or so after the car is locked and fully "gone to sleep" - my L322 used to do that.
Post #648123 15th Nov 2022 10:37am
Fox889
I'll try that tonight although I'm pretty sure it was 'hours' after I'd looked her away.
There's two earth points on the hatch, I'm wondering if that could be an issue although everything works fine. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #648127 15th Nov 2022 11:04am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
replace whole lamp.
Post #648137 15th Nov 2022 2:57pm
Fox889
I did! 😂
Brand new genuine LR one, just short of £140. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #648138 15th Nov 2022 3:04pm
An LCM fault usually sir…
Post #648201 16th Nov 2022 12:57am
Fox889
I could do with a little more help if you don't mind.
I've googled/forum searched for LCM issues & mostly they relate to the older L322 [mine is the last of the L322's] & usually are associated with brake lights [x2] on when the car is locked etc. Mine is purely the third brake light.
I can't find anything that points to just the third brake light.
You know more about these girls than I'll ever do, so if you say a new LCM will fix it, I'll go with that.
One assumes there's just the one LCM [near drivers footwell?].
Appreciate any help you can give. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #648206 16th Nov 2022 1:37am
mjdronfield
Probably start with checking connections or any sign of dampness first, rather than just changing it. You never know, might be an easy fix….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #648220 16th Nov 2022 10:28am
As above, check for dampness, unplug the LCM before locking and checking if the brake light still stays illuminated. Check for continuity of wiring from the LCM to the third brake light. All standard stuff sir…
Currently not advising you change the LCM without proving the above first sir…
Craig 👍
Post #648222 16th Nov 2022 10:39am
Fox889
Thanks awfully 😁 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #648401 18th Nov 2022 8:45am
wolv79
Bulgaria 2011 Range Rover Autobiography TDV8 Santorini Black
I have the same issue but only the middle 2 leds are glowing:
Post #648887 22nd Nov 2022 5:36pm
Fox889
Double check that you’ve only got two when the brake light is on……… 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #648914 22nd Nov 2022 11:24pm
