Home > Maintenance & Mods (L322) > Third brake light |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
Try checking again 30 minutes or so after the car is locked and fully "gone to sleep" - my L322 used to do that. |
15th Nov 2022 10:37am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 659 |
I'll try that tonight although I'm pretty sure it was 'hours' after I'd looked her away.
15th Nov 2022 11:04am |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 147 |
replace whole lamp. |
15th Nov 2022 2:57pm |
I did! 😂
15th Nov 2022 3:04pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16162 |
An LCM fault usually sir… |
16th Nov 2022 12:57am |
I could do with a little more help if you don't mind.
16th Nov 2022 1:37am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7623 |
Probably start with checking connections or any sign of dampness first, rather than just changing it. You never know, might be an easy fix….
16th Nov 2022 10:28am |
As above, check for dampness, unplug the LCM before locking and checking if the brake light still stays illuminated. Check for continuity of wiring from the LCM to the third brake light. All standard stuff sir…
16th Nov 2022 10:39am |
Thanks awfully 😁 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
18th Nov 2022 8:45am |
wolv79 Member Since: 06 Nov 2019 Location: Burgas Posts: 4 |
I have the same issue but only the middle 2 leds are glowing:
22nd Nov 2022 5:36pm |
Double check that you’ve only got two when the brake light is on……… 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
22nd Nov 2022 11:24pm |
