Home > Maintenance & Mods (L322) > Digital speedo for 2010-12 models with Gap IID tool
Page 2 of 3 <123>
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
And in case if some don't know, "Sport Mode" = "Manual Mode" when transfer case in Low-range.
Post #648349 17th Nov 2022 5:18pm
Pete, while you’re in there playing with your IID tool. Check the coolant low warning is active along with oil pressure & oil level alarms… Most I check have never been initiated in PDI!!! Banging Head Banging Head Banging Head
Post #648351 17th Nov 2022 5:56pm
Oh and the service indicator! Basically check everything that should be activated in PDI Whistle Whistle Whistle
Post #648352 17th Nov 2022 5:57pm
DrRob
Is there a PDI specific menu? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #648357 17th Nov 2022 6:15pm
Craig, I read your other post and checked the 405 that didn't have low coolant, low oil level or low oil pressure on... IID is now linked to the 405 so can't check the 322...
Dr Rob, no specific menu on the 405, don't know about the 322... I can't remember one though.... Pete
Post #648358 17th Nov 2022 6:20pm
JayGee
There is no option in the GAP IID (CCF - IPC instrument pack) to turn these off/on on my L322. Maybe other workshop tools have this ability? 2012 TDV8 Vogue (L322)
Post #648359 17th Nov 2022 6:39pm
I think it maybe in the full list that you only get from Gap if you ask... it's the untested segment... Thumbs Up Pete
Post #648372 17th Nov 2022 8:27pm
pcourtney
Most have never been initiated in PDI!!! Banging Head Banging Head Banging Head
Did anyone contact GAP about this, would be nice to have Coolant Warning and Oil Warnings activated !
Post #650994 17th Dec 2022 6:37pm
JayGee
Coolant and oil warnings are activated on mine by default. AFAIK they are visible values ( off/on) in the engine data live values. 2012 TDV8 Vogue (L322)
Post #650995 17th Dec 2022 6:46pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
All good stuff thank you Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #651014 17th Dec 2022 8:27pm
Dragonoak4x4
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Thank you for this I have now activated it on mine.
 2005 D3 4.4V8 LPG
2012 L322 Westmister 4.4 TDV8
Post #692508 13th May 2024 9:29am
My pleasure, excellent...... Thumbs Up
Double locking with one key press is another good one... and fold in mirrors on locking gives you a visible indication the car is locked... Thumbs Up Pete
Post #692520 13th May 2024 12:14pm
JayGee
I could never get the mirrors to reliably fold in everytime with one key press double locking. 2012 TDV8 Vogue (L322)
Post #692523 13th May 2024 1:51pm
Weird, worked fine on the two I had...!! Pete
Post #692524 13th May 2024 2:03pm
pcourtney
You used IID to turn them On/Off - I'm lost, I am still manually going into the menu on the LCD screen to see if my oil is mid way ish on the Vertical scale they show you in the Service Menu.
NB Am presuming if Coolant and Oil levels are low then a warning appears in the LCD cluster - somewhere !
Post #692643 14th May 2024 6:04pm
Page 2 of 3 <123>
