![]() | Home > Maintenance & Mods (L322) > Digital speedo for 2010-12 models with Gap IID tool |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
And in case if some don't know, "Sport Mode" = "Manual Mode" when transfer case in Low-range. |
Oh and the service indicator! Basically check everything that should be activated in PDI |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Is there a PDI specific menu? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Craig, I read your other post and checked the 405 that didn't have low coolant, low oil level or low oil pressure on... IID is now linked to the 405 so can't check the 322...
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3347 ![]() ![]() ![]() |
There is no option in the GAP IID (CCF - IPC instrument pack) to turn these off/on on my L322. Maybe other workshop tools have this ability? 2012 TDV8 Vogue (L322) |
I think it maybe in the full list that you only get from Gap if you ask... it's the untested segment... |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1010 ![]() ![]() ![]() |
Did anyone contact GAP about this, would be nice to have Coolant Warning and Oil Warnings activated ! |
Coolant and oil warnings are activated on mine by default. AFAIK they are visible values ( off/on) in the engine data live values. 2012 TDV8 Vogue (L322) |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122 ![]() ![]() |
All good stuff thank you Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
Dragonoak4x4 Member Since: 31 Dec 2023 Location: Misson Posts: 8 ![]() ![]() ![]() |
Thank you for this I have now activated it on mine.
My pleasure, excellent...... |
I could never get the mirrors to reliably fold in everytime with one key press double locking. 2012 TDV8 Vogue (L322) |
Weird, worked fine on the two I had...!! Pete
You used IID to turn them On/Off - I'm lost, I am still manually going into the menu on the LCD screen to see if my oil is mid way ish on the Vertical scale they show you in the Service Menu. NB Am presuming if Coolant and Oil levels are low then a warning appears in the LCD cluster - somewhere ! |
