|  | Home > Technical (L405) > Help Needed - Fuel problem |
| AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400    | Fuel Injection pump? Whats the diesel pressure like at the injectors? | ||
|  11th Nov 2022 3:24pm |
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381      |
 Try changing the fuel filter. Had a neighbour get a fuel rail pressure warning on his Peugeot after running it low on fuel and then topping the tank up …he had disturbed a load of grunge in bottom of tank that then clogged filter. A cheap and easy check. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
|  12th Nov 2022 1:31pm |
| Lee350 Member Since: 11 Nov 2022 Location: Great Yarmouth Posts: 3    | Tried that and no different. Thanks | ||
|  12th Nov 2022 8:06pm |
| Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279    | I can tell you the sorry story about my tractor.
|  13th Nov 2022 4:00pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Whilst not the same fault code but worth checking the connector to the HPFP pressure sensor as it is known to cause erroneous pressure readings.
|  13th Nov 2022 7:55pm |
| Lee350 Member Since: 11 Nov 2022 Location: Great Yarmouth Posts: 3    | fixed.  Thanks for the help
|  18th Nov 2022 7:37am |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1211      | There was a similar problem on a youtube post called `Saving salvage` they found it to be the second pump, a right   | ||
|  18th Nov 2022 8:24am |
| Posting Rules
 to get to.
 to get to.
