Home > Maintenance & Mods (L322) > ...
Page 2 of 4 <1234>
GraemeS
Australia
What colour temperature are the HID globes? I had 3000K for a while which were excellent in rain but didn't perform very well at dusk.
Post #648483 18th Nov 2022 8:50pm
Phoenix
Post #648488 18th Nov 2022 9:33pm
GraemeS
Australia
Before fitting a HID kit to my D4's fill-ins I had a pair of driving lights fitted with a HID kit. I would switch-off the driving lights on bends because they made it difficult to see anywhere other then where the driving lights were lighting-up. I subsequently fitted HIDs to the fil-ins and removed the driving lights for better general use. My MY12 L322's HID fill-ins are far better than the D4's HID fill-ins, presumably due to a different reflector design even though the D4's had been re-aimed out of the trees above (possum spotters) but also with the L322's re-aimed upwards a little.
Post #648492 18th Nov 2022 10:40pm
Phoenix
Post #648494 18th Nov 2022 10:47pm
GraemeS
Australia
I just had a look at your LEDs. The comparison will be interesting.
Post #648495 18th Nov 2022 10:54pm
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
These new ARB driving lights are adjustable on the fly ! Which be the new normal for offroad lights. Unfortunately, at around $1000 a light , I won't be ordering a set soon Shocked
https://www.arb.com.au/driving-lights/intensity/intensity-iq/
Post #648498 18th Nov 2022 11:49pm
Phoenix
Post #648500 18th Nov 2022 11:58pm
Phoenix
Post #648559 19th Nov 2022 6:43pm
Phoenix
Post #648634 20th Nov 2022 3:56pm
GraemeS
Australia
Did you check the voltage at the LED while switched on using an oscilloscope to determine whether or not the 12V supply was stable? LED drivers pulse LEDs as they produce most light immediately after power is supplied, not with constant power so the flickering may not be due to the BCM switching the 12V supply on and off, which I doubt it does.
Post #648675 20th Nov 2022 8:55pm
Phoenix
Not yet, my 'scope is at work but my relatively fast DMM didn't show any spikes or drops, the pulsing (not on-off, more 70-100%) was visible to the eye and doubly so on a camera, I'm aware the scan rate may cause the appearance of strobing but the rate was the same as visible with the Mk.1 eyeball...
Post #648677 20th Nov 2022 9:03pm
Phoenix
Post #648915 22nd Nov 2022 11:26pm
GraemeS
Australia
I'll try to remember to take a picture of mine's lights with 55W HID shining on a shed wall when I arrive home after dark Friday night, not that shining on a shed wall tells much of a story.
Post #648922 23rd Nov 2022 3:41am
Phoenix
Post #648963 23rd Nov 2022 6:53pm
GraemeS
Australia
Low beam...
High beam bi-xenon only (an airline blanket is over the fill-ins)
High beam + 55W HID fill-ins.
The intensity of the HID fill-ins is far stronger than the bi-xenons but the picture doesn't show how much better the road is lit.
Post #649094 25th Nov 2022 1:03pm
Page 2 of 4 <1234>
