![]() | Home > Maintenance & Mods (L322) > Antifreeze Coolant tester possible issue |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 616 ![]() ![]() ![]() |
I've never found the bubble type of tester to be accurate. Better is a Refractometer type of tester. More expensive, I paid about £10.
What type of coolant is the tester for? you may be using the wrong one. As above, refractometer type are more accurate, cheap anything can be false economy though. My refractometer cost £38 and has passed calibration every six months for the last five years. One of the tech's bought a 'pound shop special' from one of the no-name tool vans, although it could be referenced to zero, it mis-reported by 10 degrees on first use. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494 ![]() ![]() |
3rd a refractor to look at the specific gravity of the coolant. 2015 Range Rover Autobiography 4.4 SDV8 |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244 ![]() ![]() ![]() |
Great feedback, will definitely look into a refractor based tester.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3390 ![]() ![]() ![]() |
If there is no evidence it's been changed recently I'd refresh it anyway whatever tests are available. 2012 TDV8 Vogue (L322) |
