Home > Maintenance & Mods (L322) > ...
Page 3 of 4 <1234>
Phoenix
Post #649097 25th Nov 2022 2:33pm
Phoenix
Post #649120 25th Nov 2022 5:22pm
you'll get hot and cold bulb monitoring which causes flickering...this can be switched off with a diagnostic tool... ... - .- -.
Post #649121 25th Nov 2022 5:28pm
Phoenix
Post #649123 25th Nov 2022 5:44pm
mjdronfield
Yeah, as Stan suggests, the LCM checks bulb operation on startup and when running for bulb failures… as you know… that’s prob at least the initial flicker. I don’t know enough about the ballasts and stuff to know if that is supposed to sort it.
Don’t know if mine flicker on ignition on as it’s normally just me in the car. Will try and check when I get chance.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #649133 25th Nov 2022 6:49pm
Phoenix
Post #649141 25th Nov 2022 7:32pm
mjdronfield
I don’t have ballasts on mine, don’t know what dictates whether the units need one. I know when I put LEDs in the side indicators they would only work one way round. Can’t remember what it said on the H7 LED replacements as they just worked first time. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #649146 25th Nov 2022 8:45pm
GraemeS
Australia
AFAIK MY10-12 don't have a LCM, with lighting functions controlled by the BCM and therefore might be programed differently to earlier models.
LEDs must have their polarity correct unlike incandescent globes so there's a 50/50 chance of fitting LED sidelight etc globes incorrectly.
Post #649148 25th Nov 2022 8:54pm
Phoenix
Post #649151 25th Nov 2022 9:08pm
Phoenix
Post #649220 26th Nov 2022 4:59pm
Phoenix
Post #649236 26th Nov 2022 7:31pm
GraemeS
Australia
Whilst your low beams seem to be set at about the correct height, perhaps aiming the lights a little lower to get the fill-ins lower might not have much impact on the low beam cut-off.
LR didn't seem to get the fill-ins aligned well across their various vehicles and models. The D4's were real possum spotters, your model L322 too high but not possum spotters and the MY10-12 too low. To fix the D4's I installed spacer washers under the bottom 2 bi-xenon mounts to aim the bi-xenons higher then adjusted the assembly lower, but my L322's was the easy fix of bending the globes' tabs forwards a little.
You might have to try 1 type for a while then the other to determine which you like best rather than 1 of each.
Post #649246 26th Nov 2022 9:06pm
Phoenix
Post #649252 26th Nov 2022 9:59pm
Jcsh
France
Could you please post a link for the HIDs that you recommend?
Thanks
Post #651102 19th Dec 2022 11:17am
Phoenix
Post #651176 19th Dec 2022 8:39pm
Page 3 of 4 <1234>
