Home > Technical (L405) > Transfer Case update LTB LTB00906v6
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Does anyone know if the SW update after the double flush of the transfer case oil is the version available from GAP
I’ve messaged Pat , but thought I’d see if any of you chaps had done this already
Thanks P525
4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #643877 25th Sep 2022 10:17am
theres a thread here,
https://www.fullfatrr.com/forum/post508237.html ... - .- -.
Post #643880 25th Sep 2022 10:45am
m@ttsFF
Thanks , I saw that , but it doesn’t answer the question is the SW available from GAP so I can update via the IIDtool P525
Post #643885 25th Sep 2022 10:57am
GraemeS
Australia
A recalibration rather than a s/w update is required, which the GAP tool can initiate.
Post #643894 25th Sep 2022 12:29pm
m@ttsFF
Great , I’ll give it a go P525
Post #643896 25th Sep 2022 12:47pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I did a software update through Gap, and a recalibration after.
I changed the fluid once. I will do the second swap this week. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #643977 26th Sep 2022 3:37am
m@ttsFF
Thanks P525
Post #643984 26th Sep 2022 7:54am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Curious what issues does this remedy with transfer case? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #648681 20th Nov 2022 8:30pm
m@ttsFF
A judder P525
Post #649154 25th Nov 2022 8:34pm
fisha
Jay, are you asking about what the fluid flush would solve, or what the firmware flash update would solve.
I dont know about the firmware update.
Fluid change would remove a judder from the transfer box which may be noticable if you pull away from standstill on a hard lock turn to the left or right ( say like pulling out a junction moderately fast ). You might notice a judder a bit like abs coming through the car when pulling away. New fluid goes a long way to fixing that. V8 or else ...
Post #649258 26th Nov 2022 9:30pm
Mikey
The firmware update should be done at the same time as the fluid change Thumbs Up
Post #649259 26th Nov 2022 9:32pm
