Home > Maintenance & Mods (L405) > L405 Transfer Box Oil Change & Judder Bulletin Double Fl
Page 1 of 4 1234>
pld118
The below wiki by EmiratesA380 is a good guide:
https://www.fullfatrr.com/forum/topic44954.html
Whilst it is a thread about the L322 4.4 TDV8, the guidance is applicable to the L405 too:
A Hex bit socket will undo and enable you to torque the filler and drain plugs (22nm). New plugs and washers are advisable.
The LR branded oil is called Special Transfer Box Oil, IYK500010(pictured). Exactly 1.5 litres of your existing transfer box oil should drain out. 1.5 litres should be put back in.
From LR Parts Depts. Special Transfer Box Oil is about £46 for 2 litres (2 x 1L bottles). 2 new plugs & washers are about £8.00 in total.
Note the difference in colour between old and new oil Shocked
Post #507957 8th Mar 2019 12:55pm
pld118
LTB00906v6 - Twin Speed Transfer Case Judder
Some owners might experience the below symptoms that are specified in a UK LTB.
The symptoms can occur before or after a transfer box oil change.
The LTB is:
" LTB00906v6 - Twin Speed Transfer Case Judder "
" A customer may express a concern that a judder is felt from underneath the vehicle when using steering input at low speeds, for example turning left or right at a junction. This technical bulletin has been updated due to a change to the warranty section, parts section, condition summary and service instruction. "
If you present your car to a LR Main Dealer with judder symptoms, they might suggest a transfer box double flush, road test and software update. Our car displayed these symptoms (3.0 TDv6). The procedure was recommended and resolved the issue. The LR Main Dealer applied no charge for the procedure.
The symptoms can be the subject of an LR warranty claim.
If LR AU Warranty declines the warranty claim, the MD can raise a case for LR to cover the cost via LR CRC.
Post #508019 8th Mar 2019 9:45pm
pld118
L405 Transfer case (3.0) TDv6:
Post #508104 9th Mar 2019 5:59pm
pld118
Post #508172 10th Mar 2019 2:05pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Bow down
Post #508183 10th Mar 2019 3:15pm
pld118
Post #508237 10th Mar 2019 10:30pm
number76
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
Thanks for the time taken in posting this.
Out of interest, how many miles were on on your L405 at the time this oil was changed please?. 2014 L405 3.0 V6 Autobiography Santorini Black 49k
Post #560483 7th Jul 2020 12:43pm
Lloydy
United Kingdom 2014 Range Rover Vogue SE SDV8 Loire Blue
I’ve just had this done on my SDV8, transformed the car as it felt like it was trying to pull a driveshaft out! Car is on 103k. Annoyingly had to go to a JLR specialist as I don’t have the software to allow me to do it myself but was a fairly reasonable £349.
Post #585029 24th Feb 2021 12:28am
Ashley
United Kingdom 2011 Range Rover Westminster 4.4 V8 Orkney Grey
I had this double flush done but although improved didn't cure judder completely,had to replace with a new transfer box MY17 35K miles.
Post #585065 24th Feb 2021 3:02pm
NCRover
United States
Hello Mates,
My dealer is telling me that they only service the rear differential and transfer case on the L405 with this flush and fill. The front diff apparently has no service interval according to Land Rover. Is that true from what you guys know? Are you flushing the front diff as well?
Thanks!
John
Post #588497 23rd Mar 2021 2:26am
knwatkins
You have been given incorrect information there, John. The service schedules are as follows:
Transfer box - every 5 years or 60k miles, whichever is first
Front and rear open diffs - every 10 years or 160k miles, whichever is first
If you have the optional electronic rear locking diff, the service schedule for this is every 5 years or 80k miles, whichever is first Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #588506 23rd Mar 2021 9:36am
NCRover
United States
Kev,
Thank you! Yes that dealer information seemed pretty sketchy. I wonder about these guys sometimes.
Post #588519 23rd Mar 2021 12:47pm
knwatkins
No problem John. Never trust a dealer Wink Kev
Post #588520 23rd Mar 2021 12:51pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Personally I would not leave the diffs for 10 years. I would be changing the oil every other year. It doesn't cost much or take too long but the peace of mind is well worth it.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #588533 23rd Mar 2021 2:04pm
knwatkins
I completely agree, Ivan. I replaced all of the fluids in mine when I got it and I'll be doing the same every couple of years to keep it all tip-top. Kev
Post #588600 23rd Mar 2021 9:36pm
Page 1 of 4 1234>
