![]() | Home > Maintenance & Mods (L322) > Bent door frame |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35862 ![]() ![]() |
i've read somewhere on the forum that placing a block of wood in certain places and pushing the door on said wood will bend the door into shape. ... - .- -.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2283 ![]() ![]() ![]() |
Cheers that sound like the build quality I’ve come to expect 😂 Current stable:
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Back in British Leyland days, it was a normal job in the pre-delivery inspection to bend door frames to get the seals to stop whistling air on a windy day. Standard tool was a three foot long steel bar with two pieces of round steel bar two inches long welded at right angles to the bar, one at the end, and the other leaving a 3 inch gap. Wind the window down and give it a tweak adjacent to the top of the wound down glass area. Most window frames had fixing bolts at the front of the door frame next to the A-Pillar. I have had to undo the top one to tweak the door frame to get a good seal. Trial and error job. You can put strips of hardwood each side of the frame to stop dents appearing if you need to put a lot of strain on the door. |
