Home > Technical (L322) > 10 years maintenance (Front dismantled)
Page 2 of 5 <12345>
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
If front is disassembled is it possible to easy remove both turbos?
Post #649082 25th Nov 2022 11:12am
shinchan
Spain
Phoenix wrote:
G48 (HOAT) would be the BMW specified coolant, the LION platform engines TDV6 2.7, 3.0 & TDV8 3.6, 4.4 litre were PSA / Ford designed so would use G30 OAT, which was the default coolant at the time across PSA /Ford /Ford PAG platforms.
I've also got a feeling that the TSB referred to supercharged engines but I'm not 100% sure on that.
Correct coolant arrived!
Post #649137 25th Nov 2022 7:01pm
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
@shinchan
Great work Thumbs Up
Could you please update/or send me drawing for cooling fan tool that you made? RR HSE 4.4 2006 LPG
Post #649333 28th Nov 2022 9:24am
GGDR
shinchan this is amazing Cheers, Greg
Post #649358 28th Nov 2022 4:02pm
shinchan
Spain
Not sure! When remove engine subframe I can tell you.
Post #649476 29th Nov 2022 8:50pm
shinchan
Spain
Trying to design a engine support upper bar....
Post #649477 29th Nov 2022 8:51pm
shinchan
Spain
maric995 wrote:
@shinchan
Sure! Send me a PM
Post #649478 29th Nov 2022 8:56pm
shinchan
Spain
Hi guys,
Some updates in the process. Knuckles, axles and lower arms removed , also painted new lower arms with extra couch to protect against corrosion.
Extract axles from hubs was a nightmare. Bow down .now start to prepare the knuckles, splash and dust covers to paint.
Tomorrow I'll test the engine support bar....
In the menu today more bolts to restore...
Post #649944 5th Dec 2022 10:18pm
You're doing an excellent job, will be better than new soon... Thumbs Up Bow down Thumbs Up Pete
Post #649973 6th Dec 2022 12:03pm
Epson Green
Great work, well worth the effort👍👍
Post #649978 6th Dec 2022 1:49pm
MarkMurphy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Very good eye for detail, i need a garage, haha.
Post #650064 7th Dec 2022 8:39am
shinchan
Spain
with subframe out, good accessibility, better in RH
Post #650178 8th Dec 2022 7:04pm
shinchan
Spain
The steering rack seems to be leaking Sad
Has anyone had the same experience?
Post #650180 8th Dec 2022 7:16pm
shinchan
Spain
Steering transducer a little rusted and dirt....
Wired, cleaning and mask ready to paint...
Post #650181 8th Dec 2022 7:20pm
shinchan
Spain
Steering hoses are a little rusted also...
The plan is replating them, only one have aluminium collars and this makes it impossible to be treated...
After wire and cleaning ready to replating...
Post #650182 8th Dec 2022 7:27pm
Page 2 of 5 <12345>
