Home > Maintenance & Mods (L405) > Retrofit Adaptive Cruise Control
SIMON1599
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
Does anyone know where i can possibly get Adaptive Cruise Control fitted to a 2016 Vogue, or indeed if possble.
I am aware over on Disco4 forum some members have managed to do it , but not sire if or where i can commercially get it done.
Many Thanks
Post #649721 2nd Dec 2022 9:44pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Simon
Not sure about the L405 but I 'upgraded' my L322 via the IID tool some years back - it had cruise already and also front radar (which are the 2 things it needs for addaptive)
Turned out to be a simple software / config change.
Perhaps msg the chaps as Gap (Site Sponsors) to see whats possible. Ash
2016 SDV8 AB
Post #649738 3rd Dec 2022 9:13am
its easier if the wiring loom is fitted,
https://www.fullfatrr.com/forum/topic56883...ive+cruise ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #649741 3rd Dec 2022 10:00am
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
its easier to look at the traffic !!
Post #649742 3rd Dec 2022 10:01am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I tried to do it on my 2013 Vogue a year or so ago without success. The work seems to fall into 2 categories:
Hardware: I bought a radar distance sensing unit from eBay (it was a Delphi JS301111640078 for £150) and removed the bumper to fit it. It needed a bracket (p/n LR033405 or LR060076 for £16.50). All the wiring was in place and easy to fit. I also bought the steering wheel switch (p/n LR087486 or LR037452 (LR071935?) for £30 from this forum), removed the steering wheel and again all easy to fit.
Software: At the time, I didn't have an IID so used a local indie for the CCF programming (£70). He used the JLR SDD to reprogramme the CCF and made the following changes:
1. Speed control - Current: Adaptive cruise control is fitted
2. Adaptive speed control ECU - Current: Europe
3. Adaptive speed control ECU – Current: standard blockage level -40dB
4. Collision mitigation by braking – Current: Fitted
5. Standard speed control display type – Current: Adaptive speed control full display plus priority messages
6. Speed control - Current: Adaptive cruise control with queue assist
7. Adaptive cruise control indication in instrument cluster - Current: Enabled
8. Speed control – Current: Adaptive speed control, stop and go
9. Collision mitigation by braking – Current: Collision mitigation by braking GEN3
10. Forward collision warning – Current: Forward collision warning GEN3
11. Front crash sensing system – Current: Front crash sensing system – upfront sensor
We then did a sensor alignment and all seemed to work. The sensor went through its alignment process and after a few miles the sensor flashing stopped. However, we couldn't stop a Handbrake Module error which constantly showed up in the dash as an orange warning light, so put the CCF back to where it was.
The information I found on the process can be found at:
www.fullfatrr.com/forum/topic47538.html?hi...se+control
www.rangerovers.net/threads/adaptive-cruis...-to.340817
Current status: all the parts are fitted and the Indie suggested that everything seemed to work, but there was some conflict with the handbrake module which would probably be solved by finding the correct CCF settings - which could take a lot of his time and therefore cost (the SDD is not the quickest of systems).
I've now got an IID so could try again (though I believe I need to get in touch with Gap to have the full CCF programming option), but not got around to it since, but would love to get it working. Current:
- 2013 L405 4.4 TDV8 Vogue
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #649772 3rd Dec 2022 6:20pm
SIMON1599
Quick update on this..
I have found a company that will fully fit it retrospectively, however they only operate around London Herts at mo unfortunately, which is some way from East Yorks.
Post #659227 12th Mar 2023 8:01pm
Zebedee
Could you let us know the name of this company? Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #659290 14th Mar 2023 9:27am
SIMON1599
The company i found was LR Retrofits, they quoted £1000 fully fitted, but unfortunately don't operate nationwide, they only operate in Essex/London/Hertfordshire/Kent.
Post #659364 14th Mar 2023 9:20pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
https://lr-retrofits.co.uk/land-rovers-1 TDV8 4.4 2012
Post #659376 14th Mar 2023 9:38pm
Zebedee
Thank you. I'll let the forum know if I'm able to move forward with this. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #659434 15th Mar 2023 11:02am
Zebedee
Well, they're not very communicative... It appears as if they don't want any work. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #659991 21st Mar 2023 8:43pm
Jase71
United Kingdom 2017 Range Rover Vogue TDV6 Santorini Black
interested in this too but also am a fair way away from them.. 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #660029 22nd Mar 2023 1:24pm
