Home > Technical (L405) > Noises? |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 734 |
Is it a judder when moving off and turning?
4th Dec 2022 12:22pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Thanks for your reply. There is a definite noise when turning right from a standing start coming from the rear of the vehicle best described as a ‘clonk/clank’….it happens very rarely and I cannot re-create it. I’m also aware of a slight droning sound at 20 - 25mph….. |
4th Dec 2022 12:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
you could have this problem,
4th Dec 2022 2:25pm |
Thanks for that Stan. I don’t think it’s that. The sound is more of a ‘clonk/clicking’ sound as against a thumping noise….hard to describe…..more like somethings loose/worn but I’ll try keeping the tank over half full and see what happens, thanks again |
4th Dec 2022 3:33pm |
tomo141 Member Since: 22 Aug 2017 Location: UK Posts: 77 |
I had similar with a clunk from rear on right turn. The double flush and software update fixed it no issues since.
4th Dec 2022 10:20pm |
Thanks Tomo, were you getting the clunking on a regular basis or very occasionally? Thanks |
5th Dec 2022 12:31pm |
The clunking was just now and then, it could go days without doing then it appeared. It would some times be clunk clunk, very subtle but it was there. Always on a right turn. When it went in to LR, they knew what it was straight away. Since the flush and software update its been fine. ------------------------------------------
5th Dec 2022 11:06pm |
Thanks again Tomo, sounds exactly what I’m experiencing |
6th Dec 2022 12:05am |
Van Diesel Member Since: 27 Oct 2013 Location: Norfolk Posts: 183 |
I wonder if this is what I'm experiencing. Pulling out of a junction and turning left or right, or entering a small tight roundabout from standstill, I can hear and feel resistance from the nearside rear. Feels like a lot of friction/like somethings locked up? Reminds me of the sort of sound you would expect if you had a diff lock in and tried to turn too tight? |
24th Jan 2023 9:45pm |
Yes, that'll be it. Kev
24th Jan 2023 10:51pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Drone could be tyre resonance & unrelated.
25th Jan 2023 1:23am |
