Home > Technical (L322) > Weak battery symptoms? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34959 |
what you describe suggests a new battery is required
8th Dec 2022 4:38pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Or possibly a bad earth connection. |
8th Dec 2022 4:42pm |
h18ant Member Since: 07 Jul 2022 Location: East Sussex Posts: 14 |
Is a drop test normally done at a kwik fit kind of establishment??? |
8th Dec 2022 5:16pm |
havnt been to a kwik fit for ages so not sure...you could call them. ... - .- -.
8th Dec 2022 6:04pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
How old is the battery? I'd say if it's older than 3 years on a FFRR, you're on borrowed time especially with all those symptoms. Skip the drop test and count the saving as a discount of your new battery, fit the battery yourself to keep the cost down to just the battery, check out the Tayna website.
8th Dec 2022 8:06pm |
Thanks for the replies, the battery is just coming up to two years old |
8th Dec 2022 8:12pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
What is the system voltage with the engine running, 1 min after start and no additional loads, what is the system voltage with the engine running and 'defrost' button pushed?
8th Dec 2022 9:31pm |
h18ant:
9th Dec 2022 12:06am |
Thanks for all of the advice, appreciated! |
9th Dec 2022 8:43am |
Sooo, before i went out for an adventure in the snow this morning, i started up the engine. It started fine but i had the same thing where it seems like if i put too many things on like the heated front screen, heated steering wheel and heated seats. None of it works. If I switch everything off then I can't put the heated screens back on for a while then after a few minutes, they will start up and actually demist and work.
12th Dec 2022 11:35am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1278 |
Could be or it could be the alternator, follow phoenix's guidance above..... |
12th Dec 2022 11:53am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 698 |
What is the make and spec of the battery? a cheap undersized battery could well be US after only 2 years and there's plenty to suggest it is the battery.
12th Dec 2022 2:24pm |
Looks to be an AGM Lion and it was £229. Bought in December 2020, maybe it's a duffer... |
12th Dec 2022 2:33pm |
Will do, thanks. |
12th Dec 2022 2:37pm |
