![]() | Home > Technical (L322) > 10 years maintenance (Front dismantled) |
shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 109 ![]() ![]() |
waiting to have everything ready and take them to sandblasting and plating...
THANKS!! |
THANKS!! |
THANKS!! |
The transmission pan too much rusted inside...thinking in make some hole drains! What do you think about?
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
While you have it in bits consider a new alternator!! my car has covered 130k and alternator failed yesterday |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Jayk69….I am changing my alternator tomorrow hopefully. I am not looking forward to it. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1323 ![]() ![]() ![]() |
My tip is when you slide the alternator out make a note of the position of the wire before you disconnect it. |
Good tip, cheers |
Understood! Just ordered a new alternator! Thanks!! |
Just for fun, a touch of British green underneath...
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8700 ![]() ![]() ![]() |
You should paint it dark brown, the oil leaks won't show.... |
Sinchan, i did my belts and pullies 18 months ago, i also changed the water pump as it was in bits and seemed like a good idea as these can go when changing to new belts and tensioners. Since i have done that my AC compressor failed in spring this year and as you already know my alternator failed this winter. the AC compressor is a simple fix there is an electric valve in the back of it. this is cheap to replace and i would also recommend replacing it while you car is in bits. I will try to find a link on hear that explains it. You cannot replace this valve with the compressor in place it has to come out, which is why i replaced the whole thing. had i know all this when i did my belts i would have changed the valve at that point. Keep up the good work ![]() 2014 Navara V6 - Gone 2004 Vogue TD6 - Gone Grand Cherokee - Gone Discovery V8 (LPG) - Gone Discovery TD5 - Gone |
Sinchan here is the thread https://www.fullfatrr.com/forum/topic43778.html?highlight=air+con 2012 Vogue 4.4 TDV8 - Current
