Home > Technical (L405) > Lower Tailgate failing to close electrically
Dtac122
England 2013 Range Rover Autobiography SDV6 Firenze Red
HI,
I have researched through all the posts within this forum and I can't seem to find anything that actually fits and or solves my problem!
I have had my 2013 L405 for a few months now and the lower tailgate functioned fine until I had the rear wiper replaced by a local garage.
Now it fails to close. It opens electrically fine however when you press to close it stops almost around halfway. The spring loaded boot area cover appears to sit flush open as does the lower tailgate as it appears to be horizontal
I have checked for any obstructions and there doesn't appear to be any.
The electric ram has been replaced with a new one, which hasn't helped at all?
I have attempted to follow the user handbook to reset it -this hasn't worked either!
My Icarsoft IID toll states that there is fault on the LH cinch device - or similar wording?
Does anyone perhaps any similar experience prior to splashing out and taking it to a dealer to fix?
Thanks in advance.
Post #650830 15th Dec 2022 3:41pm
this is an extract from the WM...the first few pages refer to the upper and lower tailgate..
https://www.fullfatrr.com/gallery/albums/u...osures.pdf ... - .- -.
Post #650831 15th Dec 2022 3:53pm
Gremlin500
Worth checking battery health as part of your investigations Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #650832 15th Dec 2022 4:02pm
Dtac122
Thanks for that it’s a new battery and is the same with the engine running too. Very strange.
Post #650834 15th Dec 2022 4:59pm
Dtac122
Thanks for that Stan
I have read that part and then it begins to get very technical using Land Rover II D equipment?
Post #650835 15th Dec 2022 5:01pm
if your iidtool reports a fault in the LH pinch device [cinch] then i would look at that first.. ... - .- -.
Post #650839 15th Dec 2022 6:07pm
JCW
I had a similar issue with the upper tailgate & replaced the anti-trap sensors each side to resolve. The sensors and wiring connectors are built into the trim panel.
I also bought the left / right sensors for the lower tailgate at the time but didn’t end up needing them - send me a pm if you’re interested in one or both 👍
They just clip into each side of the lower tailgate.
Post #650841 15th Dec 2022 6:49pm
Dtac122
Lower tailgate failing to close - fixed
Hi all
Finally got to the bottom of this issue having replaced most of the components- snapped wire in the lower tailgate loom. My local Indy in wymondham Norfolk (Peter Scott
) sorted this yesterday. Many thanks guys.
Post #654761 26th Jan 2023 10:00am
steve_o
I know its a couple of years - do you still have the left tailgate pinch strip/moulding ?
Post #710447 28th Jan 2025 5:33pm
steve_o
an updates on this thread
Post #710526 29th Jan 2025 1:54pm
steve_o
just checking
Post #710527 29th Jan 2025 1:55pm
JCW
PM replied to 👍 Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #710533 29th Jan 2025 2:36pm
Link to another thread https://www.fullfatrr.com/forum/topic47843.html
Post #710552 29th Jan 2025 6:39pm
