![]() | Home > Maintenance & Mods (L405) > Getting ready for an oil change |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
This time I will use Castrol. A friend will be bringing me 20L of Smith & Allen in January so will have the next couple sorted.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1777 ![]() ![]() ![]() |
@luxmoggy:
It said to warm the car to running temp before sucking out the oil. Do you drive around or just have the engine running?
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
Just warm it up to allow easy flow of the oil, you certainly dont want oil at 90+C scalding etc
@Luxmoggy:
I always used to give it a drive round in a lower gear than usual, get the temperature up to mid-point and start draining straight away. Crack the filter off, remove the filler cap - the return oilways are sufficiently large that the oil will get back to the sump quickly, otherwise you'd end up with the rocker covers full of the stuff... Draining the oil will take ~15 minutes or so, that will be plenty of time for everything not in a pressure oilway to give way to gravity. There's no benefit in waiting for the remnants to get back to sump before you start draining, you'll lose the heat and therefore the lower viscosity. |
LT Member Since: 13 Mar 2017 Location: South West Posts: 414 ![]() ![]() ![]() |
+1 for Smith and Allan oils. ![]() |
@Kot:
I've used one of the Jabsco oil extractors for many years, never had a problem with a pipe softening or coming loose (mainly because they're under suction not pressure) even with an engine that's had an enthusiastic drive around for 20 mins or so
I remember the WM and was reading the process there. Along with my question it seems clear.
D-oh! ![]() ![]() ![]() |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
I use a little 12v pump to pump my engine oil out.
The reason for replacing the filter first is to allow the oil in the filter housing to drain back to sump, if you did it after draining the sump, you'd have around 0.5l of old oil going back to be mixed with the new oil.
So I had to visit 2 shops today to get oil for the change. Not many places carry that oil and also not many bottles if they do.
