Home > In Car Electronics (L322) > No power to Infotainment System
Sonearly
I have no power to the Touchscreen, I had done a reset and firstly when restarted the remote was not working to open the doors although the car would start. I left the car for 10 mins and disconnected the battery leaving for 10 more mins and reconnected. The remote then worked. But still no power to head unit. There is no flashing light on the knob.
Is there something that I am missing ?
Many thanks
Post #642034 5th Sep 2022 11:12am
get a drop test done on the battery..it could be loosing its charge.. ... - .- -.
Post #642038 5th Sep 2022 11:30am
Sonearly
Many thanks Stan.
Not my car a neighbours, was a few issues so did a reset and feel rather embarrassed that the audio now not working.
Post #642120 5th Sep 2022 10:13pm
DAZFINCH
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
RE infotainment system no power, I understand that this a neighbours vehicle, do you know if the problem has been resolved.
I have a late 2011 tghat has developed the same issue since a visit to garage for service work and front suspension replacment.
Post #651602 24th Dec 2022 4:56pm
Sonearly
Hi
It had to have the files re flashed as the relevant ECU’s data files were corrupt and unit not recognised. Fine afterwards.
Hope it helps.
Post #651603 24th Dec 2022 5:05pm
Sonearly
Apparently common issue if you do not wait 30 mins after disconnecting battery to do reset. Also have been told to wait similar time after reset.
Post #651604 24th Dec 2022 5:08pm
Sonearly
Nearly forgot, was also told to let car completely shutdown before disconnecting battery, 20 mins approx
Post #651605 24th Dec 2022 5:10pm
DAZFINCH
Hello Sonearly.
Many thanks for your prompt response.
This all makes sense, I think the car will require a visit to the dealer in the new year. All the usual optic fire and component tests have not shown anything, the infotainment system is fully ofline.
Appreciate your correspondance, I will update this once we move forward with getting the car sorted.
Regards Dazfinch.
Post #651654 26th Dec 2022 12:06pm
