![]() | Home > Technical (L405) > Do I need a new battery...?? |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
The boot has been playing up a bit, I noticed first thing in the morning it would only open halfway then it would be OK, I guess as the engine will have been running and topping the failing battery up...
Thanks, new one on way from Tayna, like most things they have gone up a lot since last year, the Excide only comes with a three year warranty, so I bought the Enduroline, had a couple before and they lasted well.
| caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1176
I take it if you dont have the IID too for reset you could just pop in your local mechanic and they would do for you? overfinch modified |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
Lots of diagnostics will reset the BMS - you don't need to do it as the vehicle will eventually adapt to the new battery with no ill effects, if you have autostop, it will also re-enable once the charge level has been re-evaluated fully. |
Thanks guys....
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1900
Hi Pete,
Great thx Phoenix. |
Thanks, the post was tongue in cheek, it's amazing anything worked with such a low main battery voltage... as I said, a new one, an Enduroline, will be here tomorrow from Tayna who I have used for years... The post was more to let folk know that the backup battery can mask a failed main battery very successfully, and if your boot opens to halfway or starts to play up then check the main battery voltage...... __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
New battery fitted... I thought it would be a pain due to the location under the compressor under the spare wheel but I'd much rather change one on a 405 to a 322 any day....
Good to hear Pete. |
Cool!
| All times are GMT |
