![]() | Home > Technical (L405) > Do I need a new battery...?? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
The boot has been playing up a bit, I noticed first thing in the morning it would only open halfway then it would be OK, I guess as the engine will have been running and topping the failing battery up...
Thanks, new one on way from Tayna, like most things they have gone up a lot since last year, the Excide only comes with a three year warranty, so I bought the Enduroline, had a couple before and they lasted well.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
I take it if you dont have the IID too for reset you could just pop in your local mechanic and they would do for you? overfinch modified |
Lots of diagnostics will reset the BMS - you don't need to do it as the vehicle will eventually adapt to the new battery with no ill effects, if you have autostop, it will also re-enable once the charge level has been re-evaluated fully. |
Thanks guys....
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1782 ![]() ![]() ![]() |
Hi Pete,
Great thx Phoenix. ![]() |
Thanks, the post was tongue in cheek, it's amazing anything worked with such a low main battery voltage... as I said, a new one, an Enduroline, will be here tomorrow from Tayna who I have used for years... The post was more to let folk know that the backup battery can mask a failed main battery very successfully, and if your boot opens to halfway or starts to play up then check the main battery voltage...... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
New battery fitted... I thought it would be a pain due to the location under the compressor under the spare wheel but I'd much rather change one on a 405 to a 322 any day....
Good to hear Pete. |
Cool!
