|  | Home > Technical (L322) > 5.0 S/C Rich Running |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564    | I’d pull the plugs first as a quick check to see inside the cylinder.
|  1st Jan 2023 3:04pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | I would put money on it being the HPFP's don't know if they can leak internally but if they do it could get straight into the oil, not sure why it would run rich either but they are a weak spot and known to fail... If you are not getting the pressure requested then that's another indication....
|  1st Jan 2023 3:21pm |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | Thanks both for the sanity check.
|  1st Jan 2023 5:48pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Search eBay for JAGUAR XF XJ XK LAND RANGE ROVER SPORT DISCOVERY HIGH PRESSURE FUEL PUMP 5.0
|  1st Jan 2023 6:10pm |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | Thanks Pete,
|  1st Jan 2023 6:23pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | If you can't find anyone local you are only a couple of hours from our very own Craig at Cam Tech...
|  1st Jan 2023 6:46pm |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | Finally had time to pull plugs from 2, 4, 6 & 8 before I was summoned inside.
|  21st Jan 2023 3:55pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Looks to me like they weren't done up tight enough...
|  21st Jan 2023 4:34pm |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | They didn't seem overly loose but not really that tight either.
|  21st Jan 2023 5:01pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | While I have read that injector failure is commonish with these engines as well... Pete
|  21st Jan 2023 6:25pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | I was about to say the same as Pete (Haylands) - injector failure on the 5.0 isn’t undocumented and would explain over fueling as 4 and 8 are on opposite banks.
|  21st Jan 2023 7:03pm |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | I thought JLR adopted ISO standard for the AJ133 which puts 4 & 8 on the same bank?
|  22nd Jan 2023 3:05pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Would it not be worth getting the injectors tested out of the engine...? Pete
|  22nd Jan 2023 5:45pm |
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100      | I had thought about it but apparently by the time you've gone through getting them out & tested the cost isn't far off just replacing with new.
|  22nd Jan 2023 6:08pm |
| Posting Rules
 it up somehow.
  it up somehow.
