![]() | Home > Technical (L322) > New purchase 4.4tdv8 deployable steps stuck |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
they are a nice option to have. IIRC the button doesn't actually operate them as such, so pressing it doesn't deploy the steps. I can't remember exactly what it does as its been a while since I fitted them to my 322 but if memory serves it holds them
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 302 ![]() ![]() ![]() |
If you press and hold the roof button for 3 seconds within 5 seconds of ignition on it will deploy the steps for roof access. As I recall they will stay deployed until you repeat the process, the vehicle is locked or travels at >~3MPH.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
Lube the hell out of the joints as first port of call.
Not really - what I do is just leave a door ajar which leaves the steps out and also prevents suspension adjustments allowing you to jack. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
