![]() | Home > Technical (L405) > Do *I* need a new battery - yet another thread |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1899
Hi, sounds like your main battery is getting weak and can’t hold charge, hence the messages. A decent battery fully charged shoul read about 12.6V and hold that for several days in storage. Search “Battery” on here, there are loads of threads, some with links to a cheap but decent battery capacity tester. |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
I'm no expert, but if the voltage is dropping like that with nothing connected, it certainly seems like an issue with the battery.
Also, as advsed on other posts, check tailgate operation is not sluggish, its a good sign of a weak battery |
| luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507
The main battery that I took out of the car acted like that one. Was told by a dealer that it just needed charging. I also charged it after I replaced it (to keep it for spare if was OK). But the voltage dropped quickly.
| MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135
Thanks guys, I think we're in agreement that i need a new one.
If you're referring to the Kingbolen BM580 which I have. This is after I'd finished taking readings today: Res 3.43mOhms CCA 674A STD 850A Vol 12.44V SOH 63% SOC 73% Result Normal I guess the CCA should equal the input value of 850 on a perfect battery or is it just calculating that from the voltage which is low anyway. That would mean going in my wife's 1.0L 3 cylinder VW Up 2014 FFRR 4.4 SDV8 Autobiography Barolo Black 2012 RRS SDV6 HSE Baltic Blue and before I saw the light: 2011 Suzuki Grand Vitara SZ5 1998 Ford Mondeo V6 Ghia X 1990 Citroen BX GTi 1973 Triumph GT6 |
That's all very useful. I've noticed that my second battery is called on to help unlock the car judging by the synchronised voltage drops on the two batteries. So the second one seems to do more than just the documented help with starting. Chris 2014 FFRR 4.4 SDV8 Autobiography Barolo Black 2012 RRS SDV6 HSE Baltic Blue and before I saw the light: 2011 Suzuki Grand Vitara SZ5 1998 Ford Mondeo V6 Ghia X 1990 Citroen BX GTi 1973 Triumph GT6 |
| adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884
It does indeed, at least on the PHEV variant: https://www.fullfatrr.com/forum/post650227.html#650227 |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
Having had Lion batteries in cars I’ve bought before, I’d never have another again. They don’t last 5 minutes in my experience.
| All times are GMT |
