![]() | Home > Technical (L322) > L322 Dipped Beam Failure |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Here you go...
GUMBALLER Member Since: 22 May 2022 Location: Hampshire Posts: 40 ![]() ![]() ![]() |
Many thanks |
Many thanks |
So, after testing it appears I have no power on the dip beam wire.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
On a 2002 it'll be BMW electronics. The BMW light control module or LCM maintains a series of counters for short circuits, bulb failures and so on. If the counters reach a certain threshold the LCM disables the power feed to the circuit or circuits affected. The counters can only be reset using diagnostics, which on a BMW would be done with Tool32 from the BMW Standard Tools.
Much appreciated Danb_220_2019 |
Very much appreciated ![]() |
No worries! |
