Home > Maintenance & Mods (L405) > oil cooler replacement how to?
andygts
Mine has been emitting fumes for a while but has progressed to dripping oil on the drive so I'm going to have to sort it.
From what I've read the L405 is a bit more involved than the L322. what else actually has to come off and how long does it take roughly? the manual I've found only shows removing the actual cooler unit. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #650865 16th Dec 2022 8:54am
fisha
Which oil cooler ? V8 or else ...
Post #650883 16th Dec 2022 11:00am
andygts
The one in the V on the engine Current
Previous
Post #650902 16th Dec 2022 1:30pm
andygts
Decided to take the plunge and do it myself and save a fortune....or so I thought.
Wipers off
Scuttle off
sound deadening / heat shield off at the rear of the engine
The rest is same as as L322 but once started you can see what needs to be removed. It looks a big job but it isn't.
My issue was I found a coolant leak while I was in there.....the plastic elbow in the top of the thermostat housing had turned to cheese. it was weeping but once touched literally crumbled Censored
Not the best situation to be in @ 11:30 on a saturday morning needing a dealer only part. The local stealers pointed me at another branch not a million mile away from my brothers so I sent him round before they closed only to be told they had the part but it was reserved for a job. Censored Censored Censored Censored
Not happy but nothing I could do, I bodged an elbow together to make the car movable as like a tit I'd blocked my 911 in so was stuck. ordered the elbow again from my local stealer to arrive tuesday.
Tuesday came no phone call so rang them to be told it was on back order and so was it's parent part with no lead time other than end of Jan at the earliest Censored
After some frantic ringing round various garages / parts suppliers I managed to find a complete thermostat housing 15 mile away....Ended up paying just short of £70 for a big bundle of pipes / housing / sensor just to rob a small elbow off it Big Cry
And to top it off the Mrs' evoque has decided to start leaking haldex fluid from the pinion seal Censored
Why do things never break in the summer when it is nice and warm and dry? Current
Previous
Post #651790 28th Dec 2022 12:29pm
A normal day in the life of a RR owner..... Rolling Eyes
Sorry to hear your experience, at least that's the three things broken now.. Shocked Pete
-Click here for Thread-
Post #651793 28th Dec 2022 1:35pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I don't suppose you'd write up the process and put it on here?
It's a job i need to do in the new year.... Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #651798 28th Dec 2022 3:02pm
And post a picture and the part number of the part in the cooling system that failed..... Thumbs Up Pete
Post #651862 29th Dec 2022 12:33am
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Fair play to all those doing this job themselves. Had mine replaced early last year. From memory wasn't hugely expensive at the independent I use, although I did provide the parts.
Post #652036 30th Dec 2022 12:28pm
andygts
The part number on the pic is all I required or actually more than I required, it comes with the rubber pipe, I just needed the elbow. I've ended up with everything in that diagram.
as far as a guide goes it really is self explanatory once you start
wipers off
plastic scuttle panels off
remove the 2 strut braces
this then allows you to remove the sound deadening / heat shield
(You'll now be at a point where there's plenty of L322 guides if you do get stuck)
Remove the engine cover
remove the inlet:
    2 brackets either side to unbolt which hold pipework
    undo the 4 hoses and slide them inwards
    remove inlet mounting bolts, couple at the rear then 4 on a big plate at the front (some pipe / cable clips on this also)
    remove 2 bolts from EGR pipe (engine side)
    unlpug MAP sensor and unclip pipes / cables from throttle body
    unplug throttle body and remove inlett pipe securing clip
The inlet should now wiggle out in one big lump. (careful on the elbow on the thermostat housing)
The oil cooler will is now staring you in the face.
swap it over and fit in reverse.
You may also need extra .....
O rings for the pipe at the rear (common to leak if it isn't the cooler itself causing the issue) I'D REPLACE THESE REGARDLESS AFTER READING SOME OF THE THREADS ON HERE
I appear to have got away with the water feed to the oil cooler (rubber seal inside the push fit can leak)
EGR pipe metal gakset (I've got away with re using that aswell)
[/list] Current
Previous
Post #652404 3rd Jan 2023 9:08am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Mine broke too but i could not locate a part number and needed the car back on the road. so i doctored a fix.
I removed the plastic pipe that joins it and replaced it with a normal rubber hose. I removed the fitting and added one of these pipe connectors
No leaks and better than the original. Oh i also did away with the standard pipe clamps and replaced with jubilee ones 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #652439 3rd Jan 2023 2:22pm
andygts
What retains it? the original has a plastic clip that locks it the thermostat housing. Current
Previous
Post #652467 3rd Jan 2023 8:56pm
Jayk69
Andy,
i see what you mean i had a different pipe that broke
i eliminated the male and female connector with the elbow. but it is a different hose reviewing your post. sorry speed reading and all that. 2012 Vogue 4.4 TDV8 - Current
Post #652484 4th Jan 2023 9:52am
Jayk69
This is the pipe i changed
Post #652485 4th Jan 2023 9:56am
andygts
Same pipe just opposite end, god knows why they've paid someone to come up with this invention when barbed fittings and jubilee clips have done the same job for the last century+
 Current
Previous
Post #652502 4th Jan 2023 3:54pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I now have the exact same problem oil cooler been replaced at garage they noticed a slight weep from the thermostat housing water outlet part number LR110459 managed to get this eventually but then the elbow broke off the water outlet connection part number LR036058 and we cannot get this anywhere on back order apparently this is for the whole assembly and I only need the elbow.Cheers for the part number for the hose with elbow only but can't get this anywhere so other alternative is to buy another make vehicle similar hose with the same end elbow connectors we have found the same end elbow connector on a Range Rover 5.0 V8 bleed hose see image
so hopefully this will fit fingers crossed!Any other Idas much appreciated guys. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #653956 18th Jan 2023 10:28pm
