Home > Technical (L405) > Remote climate control fob or climate control by App
Bluebird
Wales 2016 Range Rover Autobiography SDV8 Santorini Black
I have a 2016 RR autobiography 4.4 V8 diesel (2017 model). With these cold mornings, I used the climate control on the app for 30 mins and it worked great. I also have a fob which came with the keys.
Just a few questions
. Is working on the fob the same system ?
2. If not which is the best system to use?
3. As I am warming up the car for 30mins will it help with oil dilution?
Thanks as always for your help.
( still love the car, and had over a year)
Post #654131 20th Jan 2023 1:28pm
Martin2
Assuming it’s the same as mine, the App remote starts the engine but the fob turns on the FBH (Fuel burning heater) so you should definitely use the fob to defrost and warm the car up rather than run the engine. It’s takes about 20-25 mins in my car, depending on how far below freezing it is.
If you want to cool the car in the summer, then the app. / remote start is the only option. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #654134 20th Jan 2023 1:53pm
Bluebird
Thanks for that. Except for the light on the fob, how would I know if it works. With the app, and the engine running I know it is working.
Post #654136 20th Jan 2023 2:03pm
Bluebird
Just turned the fob on and can hear the heater going- thanks Martin
Post #654137 20th Jan 2023 2:33pm
Kot
Anyone know where can you get a fob from? price? etc would the hardware etc be already installed to work with the fob?
I used to use the app which was great, but since I have fitted the Ghost2 I cant remote start the car anymore to do a defrost etc
I wonder if I can get around that with a fob? Why didn't they incorporate that function into the vehicle key fob? 2018 SE SDV8 4.4 Byron Blue
Post #654138 20th Jan 2023 3:00pm
Gremlin500
@Kot:
I think the FBH is only standard on the AB, others may put me right or confirm. Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #654141 20th Jan 2023 3:42pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
If I use the Fob, InControl App or Timed Climate, it is the same result that it just starts the FBH. Which one starts the car? SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #654145 20th Jan 2023 3:56pm
Martin2
You’re welcome. Thumbs Up MY23 Panamera E-Hybrid
Post #654146 20th Jan 2023 3:59pm
Martin2
Gremlin500 wrote:
@Kot:
You are correct! MY23 Panamera E-Hybrid
Post #654147 20th Jan 2023 3:59pm
Martin2
I’ve only used the app to cool the car, I haven’t tried it to heat as I’ve always used the fob, but in the app it says “Engine will start to power climate”, so I’m surprised it only starts up the FBH. I’ll try it later.
Timed climate uses the FBH, I’ve used that when staying in hotels and out of range of the remote. My main office is two stories up and quite a way from the carpark, but I know where the park the car so there’s clear line of sight and it’s in range of the remote! MY23 Panamera E-Hybrid
Post #654148 20th Jan 2023 4:02pm
luxmoggy
The comment in the app I have is "You can only use climate control once per manual engine start, this is to keep your battery charged."
Nothing about the engine start. I wonder if there is something different between engine types and markets on which the car is sold in.
My Climate screen is different. I don't have a target temp either
 SDV8 AB MY 2020
Post #654152 20th Jan 2023 4:35pm
luxmoggy
REMOTE CLIMATE CONTROL
Prepare your Land Rover in advance by setting temperatures to keep you and all your passengers comfortable from the moment you step inside. It is powered by remotely starting the engine.*
*If the engine cannot be remotely started because of vehicle or market limitations, remote heating and venting is still possible if Timed Climate or Remote Park Heat is fitted. If neither is possible, the Remote Climate feature will not show in the InControl Remote smartphone app. SDV8 AB MY 2020
Post #654153 20th Jan 2023 4:55pm
knwatkins
Martin2 wrote:
Gremlin500 wrote:
@Kot:
You are correct!
I'm afraid this is not correct. The FBH is standard on the SDV8, irrespective of trim level.
By the way, if anyone wants to retrofit remote climate to trigger the FBH, I wrote a guide for the forum a couple of years ago here:
https://www.fullfatrr.com/forum/topic57037-15.html Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #654160 20th Jan 2023 5:55pm
TJH1985
MY16 here, the app & fob do the same thing and just fire up the FBH. I have the same warning re only once per manual engine start as well. Thumbs Up
knwatkins wrote:
Martin2 wrote:
Gremlin500 wrote:
@Kot:
You are correct!
But they don’t all have the change over valve to facilitate the rapid heat up for the park heater AFAIK even if you enable it. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #654164 20th Jan 2023 6:30pm
Bluebird
When I started the fob I could hear the heater but the engine did not start, but with the control app the engine starts. Are we saying that the Fob and the control on the app use the same system. I am sure I saw something I saw that said they use different systems.
Post #654165 20th Jan 2023 6:36pm
