|  | Home > Technical (L405) > Remote climate control fob or climate control by App |
| Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802    | Assuming it’s the same as mine, the App remote starts the engine but the fob turns on the FBH (Fuel burning heater) so you should definitely use the fob to defrost and warm the car up rather than run the engine.  It’s takes about 20-25 mins in my car, depending on how far below freezing it is.
|  20th Jan 2023 12:53pm |
| Bluebird Member Since: 30 Aug 2021 Location: Cardiff Posts: 98      | Thanks for that. Except for the light on the fob, how would I know if it works. With the app, and the engine running I know it is working. | ||
|  20th Jan 2023 1:03pm |
| Bluebird Member Since: 30 Aug 2021 Location: Cardiff Posts: 98      | Just turned the fob on and can hear the heater going- thanks Martin | ||
|  20th Jan 2023 1:33pm |
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442    |
 Anyone know where can you get a fob from? price? etc would the hardware etc be already installed to work with the fob? I used to use the app which was great, but since I have fitted the Ghost2 I cant remote start the car anymore to do a defrost etc I wonder if I can get around that with a fob? Why didn't they incorporate that function into the vehicle key fob? 2018 SE SDV8 4.4 Byron Blue | ||
|  20th Jan 2023 2:00pm |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1902      | @Kot:
|  20th Jan 2023 2:42pm |
| luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507      | If I use the Fob, InControl App or Timed Climate, it is the same result that it just starts the FBH. Which one starts the car? SDV8 AB MY 2020
|  20th Jan 2023 2:56pm |
 You’re welcome.  MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold | ||
|  20th Jan 2023 2:59pm |
 You are correct! MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold | ||
 I’ve only used the app to cool the car, I haven’t tried it to heat as I’ve always used the fob, but in the app it says “Engine will start to power climate”, so I’m surprised it only starts up the FBH. I’ll try it later. Timed climate uses the FBH, I’ve used that when staying in hotels and out of range of the remote. My main office is two stories up and quite a way from the carpark, but I know where the park the car so there’s clear line of sight and it’s in range of the remote! MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold | ||
|  20th Jan 2023 3:02pm |
| luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507      | The comment in the app I have is "You can only use climate control once per manual engine start, this is to keep your battery charged."
|  20th Jan 2023 3:35pm |
| luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507      | REMOTE CLIMATE CONTROL
|  20th Jan 2023 3:55pm |
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782      |
 I'm afraid this is not correct. The FBH is standard on the SDV8, irrespective of trim level. By the way, if anyone wants to retrofit remote climate to trigger the FBH, I wrote a guide for the forum a couple of years ago here: https://www.fullfatrr.com/forum/topic57037-15.html Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey | ||
|  20th Jan 2023 4:55pm |
| TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 675    | MY16 here, the app & fob do the same thing and just fire up the FBH. I have the same warning re only once per manual engine start as well.
 But they don’t all have the change over valve to facilitate the rapid heat up for the park heater AFAIK even if you enable it. MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry! Previously Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90  Last edited by TJH1985 on 20th Jan 2023 5:38pm. Edited 1 time in total | ||
|  20th Jan 2023 5:30pm |
| Bluebird Member Since: 30 Aug 2021 Location: Cardiff Posts: 98      | When I started the fob I could hear the heater but the engine did not start, but with the control app the engine starts. Are we saying that the Fob and the control on the app use the same system. I am sure I saw something I saw that said they use different systems. | ||
|  20th Jan 2023 5:36pm |
| Posting Rules
